Metal Vs Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 09:54 AM   #16
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Originally Posted by titanoman View Post
You are ignorant to think you have a clue about my abilities. The messes I make? You don't know me. Who the **** do you think you are, you little pansy?
I could quite possibly be wrong about your abilities. I was just basing my assessment on the advice you gave. That was all I had to go by.
The OP was barely informed (probably by some infomercial) and came here to broaden his knowledge base.
Without knowing his roof, it's hard to say whether it would be simple or not. A poorly installed metal roof can be more of a liability than an asset.
seeyou is offline   Reply With Quote
Old 01-21-2012, 10:14 AM   #17
Civil Engineer
Rewards Points: 4,682
Do not confuse the warranty period with the actual length a roof will last. I have done over 200 forensic insurance investigations on houses that have been damaged (wind, water, hail, impact, foundation failure etc.) and I have never met anyone who collected on a roof warranty. The reasons they fail to collect are multiple, sometimes the roofer is out of business, usually they did not read the warranty carefully, and did not realize that they were prorated material only, etc.
So in my experience, length of warranty is loosely, or maybe not at all, correlated with product lifespan. For example, those of you married out there, you probably think you have a lifetime warranty, but most marriages will end in divorce. Go try to collect on that warranty.
As to roof materials, I can certainly speak to roof performance in hurricane country, having done about 180 damage inspections after Katrina and Rita. Low cost three tab asphalt shingles are about the worst, they rarely survive even a minor hurricane, and if they do they need to be replaced. Heavy weight architectural shingles do pretty well, especially if they are properly attached (four or five nails per shingle, high grip nails). I have photos of houses along the coast where one house has three tab shingles, essentially destroyed, and the house next to it has architectural shingles, relatively little damage.
High quality metal roof, properly installed, do very well. When I inspected Jim Bob's pool hall after Katrina, the metal siding was destroyed, but the metal roof was perfect. Very interesting case, pretty typical of quality roof installation. Poorly installed metal roof are catastrophic in hurricanes, the roof comes off in sheets, becoming a lethal hazard.
Clay tile roofs did surprising well, the biggest issue was tile damage from flying debris. They are not common, and they require special installation techniques, but they seem to last a long time, and perform well under stress. As do slate roofs. I inspected half a dozen homes in New Orleans area with real slate roofs, absolutely minimal damage. Again, hard to install correctly, heavy, and expensive. A good slate roof might last a hundred years with reasonable maintenance, which is longer than any other type of roof I have looked at.
As to installing a roof yourself, well this is no different than any other skilled trade, it is always MUCH HARDER than you think it is going to be, and the results on the first try are likely to less than optimal. As to saving money, how much is your time worth? If the answer is zero, and you don't mind suboptimal results, have at it. Personally I do a lot of my own work, but I never try to justify it by claiming I am saving money or doing a better job than a trained professional, I do the jobs because I enjoy the experience. I wouldn't touch roofing, too dangerous, too difficult, but to each their own.
The Following 8 Users Say Thank You to Daniel Holzman For This Useful Post:
Ironlight (01-24-2012), kwikfishron (01-21-2012), mae-ling (01-21-2012), OldNBroken (01-21-2012), rossfingal (01-21-2012), seeyou (01-21-2012), tinner666 (01-21-2012), Windows on Wash (01-22-2012)
Old 01-21-2012, 10:29 AM   #18
Experienced
Jackofall1's Avatar
Daniel as always your perspective is interesting and based on a great dealo of experience.
On the subject of warranty and marriages, that all depends on what side of the coin you are on, she for instance collected a bundle.......
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
Old 01-21-2012, 01:07 PM   #19
Rewards Points: 2,210
There are many different types of metal roofing, What type is the OP talking about?
mae-ling is offline   Reply With Quote
Old 01-21-2012, 01:16 PM   #20
Rewards Points: 774
Originally Posted by Windows on Wash View Post
I just spit my coffee all over my monitor.
The newer metal systems out there look better than asphalt when you ask most customers.
That not withstanding, good metal is an investment for certain.
Whether they last that long or not is a matter of many factors.....but even low end shingles have 30 yr warranty
cibula11 is offline   Reply With Quote
Old 01-21-2012, 01:28 PM   #21
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,034
Sure...and the paper they are written on is probably more useful for starting a fire than enforcing the warranty.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 01-21-2012, 01:39 PM   #22
Rewards Points: 774
True....but it's not the shingles' fault or the manufacturer that roofers don't install them to the specifications in the warranty.....and I know that it is near impossible with some manufacturers to meet their warranty terms.
Old 01-21-2012, 02:07 PM   #23
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Most 3-tab is 20yr.
titanoman is offline   Reply With Quote
Old 01-21-2012, 03:03 PM   #24
Is this a joke?
Please don't tell me that you think the primary reason for premature failure of shingle roofs is all installation issues.
We are getting ready to replace 2 roofs that are 10-14 years old and are installed well withing manufacturers required specifications.
Old 01-21-2012, 03:22 PM   #25
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Most 3-tab is 20yr.
Very few 3 tabs get installed around here anymore, but the only ones stocked carry a 25 yr warranty. I think there are some 20 yr shingles still available in limited color selection (black primarily) as special order.
I just looked at Certainteed's site and they only ship 25 and 30 yr 3 tabs to my area. Same shingles that used to have a 20 year warranty. Curious.
Old 01-21-2012, 03:48 PM   #26
Disabled wood vet
titanoman's Avatar
Tells you what I know.
Yeah, that is curious...hmmm
Old 01-21-2012, 04:11 PM   #27
Funny how that work now. Shingle warranties growing...?
Old 01-21-2012, 09:38 PM   #28
Msradell's Avatar
Rewards Points: 170
Originally Posted by Ycreek View Post
Oh, and by the way, good luck on getting 20, 25, or 30 years out of ANY asphalt roof. It can happen but it's rare.
A lot of it depends on where you live. I've certainly seen many go this long or longer, especially in climates where it doesn't get excessively hot!
Msradell is offline   Reply With Quote
Old 01-22-2012, 10:54 AM   #29
Rewards Points: 280
I'm just a homeowner, not a roofer.
I would never install screw-down metal roofing to a house. Only standing seam.
I would never install any roofing material over existing roofing material. I would always remove the old roofing to allow for sub-structure inspection and repair if necessary. I don't want to install a 50 year metal roof and not know the condition of the existing sub-structure.
Earnie is offline   Reply With Quote
The Following User Says Thank You to Earnie For This Useful Post:
seeyou (01-22-2012)
Old 01-22-2012, 12:16 PM   #30
Rewards Points: 774
Is this a joke?
IF they were installed within the manufacturers specifications, then I assume the roof is under warranty and that warranty would cover the replacement.
And no, I don't think the primary reason for failure is installation, but it is one cause and a pretty common one too.
New Shingles: Defective Shingles or Bad Install? TTZip Roofing/Siding 9 04-30-2013 01:03 AM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Metal Roof Estimate supton Off Topic 5 04-17-2010 03:08 PM
shingle over??? lemeno Roofing/Siding 12 12-01-2007 11:39 PM
