Metal Vs.Shingle - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-25-2011, 09:17 AM   #1
Metal vs.Shingle
So I'm in search of the best roofing option and it appears local contractors can't give me a straight answer so here I am... What is better, a 30 yr arch. shingle OR Metal roofing?
Coach J is offline   Reply With Quote
Old 05-25-2011, 09:32 AM   #2
Rewards Points: 2,238
What kind of metal - steel, copper, tin, etc... ?
rossfingal
rossfingal is online now   Reply With Quote
Old 05-25-2011, 07:23 PM   #3
A cheaper and thinner quality metal roof and any inferior fastening system would not provide the long term benefits supposedly derived from the higher quality metal roofs.
A high quality metal roof, regardless of material product choice will cost substantially more than a 30 year architectural shingle.
So, what really needs to be determined, is what is your budget for the project?
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-26-2011, 07:55 AM   #4
Residential Roofer
Slyfox's Avatar
There is no comparison to the two systems.
Compare the metal roof to a designer shingle, the cost an longevity are closer with those two but the metal will still hold up longer if installed properly.
The metal roof will still cost more then even the designer shingle.
Like the first to posters said, what type of metal system and what type of structure it will be installed on will determine the longevity of the system almost as much as the installation spec's/workmanship.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 05-29-2011, 07:51 PM   #5
Wow, now you have me thinking... The company gave me 2 options and I'll tell you what, I'm a little lost. (one is $1.85 lf and the other is $2.05 lf) I'm not too entirely sure what the difference is. I have a 51 square roof and I know it will cost a small fortune to have it in metal, however everytime I go to mow the lawn... there's another shingle off. I'm in a high wind area and a concerned with longevity. I appreciate all of your responses!!! Thank you so much!
Tags
metal roofing , shingles
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 01:21 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 06:54 AM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
