Metal Roofs: Exposed Fastener Vs Standing Seam - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-12-2014, 04:38 PM   #1
Rewards Points: 133
Metal roofs: exposed fastener vs standing seam
I'm collecting bids for replacing my shingles with a metal roof and the last two guys have had really similar bids for exposed fastener and standing seam jobs; only about $500 more for standing seam. They both said that they preferred exposed fastener roofs, and that standing seam was overkill for our climate (< 10" of rain a year). One of them said that standing seam roofs are harder to repair and retrofit later if I or a future owner wanted to put in something like a skylight or a roof-mounted cooling appliance.
My impression is that standing seam roofs are much higher quality, so these views surprised me, as did the small difference between the bids for exposed fastener vs standing seam.
Are these guys right? Are they so wrong that I shouldn't even consider them?
iLikeDirt is offline   Reply With Quote
Old 05-12-2014, 04:46 PM   #2
Rewards Points: 13,752
Standing seam is a far better roof!
Unless this was just for a pole barn I would not even consider anything with exposed screws.
The Following 5 Users Say Thank You to joecaption For This Useful Post:
concretemasonry (05-12-2014), kwikfishron (05-12-2014), roofermann (05-13-2014), tinner666 (05-12-2014), Windows on Wash (05-13-2014)
Old 05-12-2014, 04:51 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I think I'd keep shopping. SS is harder to install 'fast'. Both are easy to screw up, but stay away from exposed fasteners. Personally, I refuse to even bid EF roofs.
tinner666 is offline   Reply With Quote
Old 05-12-2014, 06:31 PM   #4
Rewards Points: 650
I bet they weren't offering a true ss roof, maybe a snap panel? There is no way $500 even comes close to the cost difference.
They are correct that hidden fastener roofs are complicated to repair, so make sure its done right.
PatChap is online now   Reply With Quote
The Following User Says Thank You to PatChap For This Useful Post:
tinner666 (11-26-2014)
Old 05-12-2014, 06:35 PM   #5
Rewards Points: 133
The panel they would be using is the McElroy Meridian standing seam panel (http://www.mcelroymetal.com/content/...?product_id=13), which is not mechanically-seamed; the panels are directly screwed down on one side, then those screws are covered by the next panel, and the seams are snapped together. Is this a poor product? It seems to be the only standing seam panel locally available. The roof is 25 squares and so far I have gotten one bid for 14k and two for 10k. All three would be using the Meridian panel.
Old 05-12-2014, 07:00 PM   #6
Rewards Points: 650
Looks like a standard snap panel. Snap panels are a good option, especially on simple buildings. They aren't as wind resistant, more prone to oil canning. Whether or not it holds up is all in the details.
Old 05-13-2014, 12:26 PM   #7
Low Slope Roofing
Rewards Points: 114
What gauge of standing seam? $500 IMO isn't enough of a difference between the two panels. Something is being forgotten. Most standing seam has separate clips to hold the panel in place, these have a flange. That would lead to more oil caning and the panel would not be able to move as it should. I'm guessing they must be a fairly inexpensive panel. You can get better panels shipped anywhere.
1985gt is offline   Reply With Quote
Old 05-13-2014, 12:27 PM   #8
Rewards Points: 133
It would be 26 gauge.
Old 05-13-2014, 12:29 PM   #9
Low Slope Roofing
Rewards Points: 114
I'd go heavier, 24 gauge, it helps with the oil canning, also the ribbed panels will be better also.
For the exposed fasteners I doubt if they are more then 28 gauge.
Old 11-25-2014, 03:43 PM   #10
Rewards Points: 16
There is nothing wrong with a properly installed through screwed roof, except maybe the price you were quoted. Even at retail prices through big box stores like The Home Depot, through screwed 29 gauge roofing with a lifetime warranty should run about $80 per square for the steel roofing. I'd not recommend a concealed fastener panel unless you are doing it because you absolutely love the appearance.
PoleBarnGuru is offline   Reply With Quote
Old 11-25-2014, 03:59 PM   #11
Rewards Points: 133
How come? You don't like them?
So for a 26 square roof, your idea of the price comes to about $2,000. Surely that's the price for materials only, no? If I could find someone willing to install a metal roof on my house for two grand, I'd do it yesterday!
Old 11-26-2014, 04:49 AM   #12
Pro Slate Roofer
tinner666's Avatar
I love the eerie sounds coming from under an EF roof as the sun hits it in hte morning and the metal starts moving. Those sounds mean money for the guy that's going to replace it for you.
Take a one foot square piece of metal and screw of nail it to a piece of wood and lay if where the sun can hit it. Right beside it, lay another piece beside it and watch it lay dormant. That's the difference. All that movement wallows the holes out and leaks occur. No ifs, ands, or buts about it.
The Following 2 Users Say Thank You to tinner666 For This Useful Post:
1985gt (11-26-2014), roofermann (11-26-2014)
Old 11-26-2014, 09:39 AM   #13
Low Slope Roofing
Rewards Points: 114
"lifetime warranty"
http://www.homedepot.com/p/Fabral-PL...z0sdg7Z1z0v4pe
$ .80 a square foot for the panels only, no trim, felt, fasteners ect. Just galvanized, no colors and no warranty for the finish.
They are just not a good roof to have on a home. On a metal building sure, we have one on our shop it's 24 ga. Every temp change it pops. The building is less then 7 years old and we have already begun to replace fasteners. This is on an all metal building, the expansion and contraction rates should be closer together then a wood structure.
IMO I'd spend a few extra coins for a SS roof.
The Following User Says Thank You to 1985gt For This Useful Post:
Old 11-26-2014, 01:31 PM   #14
roofermann's Avatar
Rewards Points: 401
Me too, unless by SS you stainless steel!
roofermann is offline   Reply With Quote
I feel dumb - how to attach something to metal Zephie General DIY Discussions 3 07-11-2012 06:37 AM
Sealant for exposed fastener metal roofing? dweeter Roofing/Siding 4 04-17-2012 11:07 AM
Range vent in new exposed fastener metal roof Greg Shubert Roofing/Siding 28 01-04-2012 08:25 AM
Old shingled to Metal? Sorry...looong! ladynga Roofing/Siding 1 08-31-2011 04:27 PM
Vast overpricing of metal roofs ? Texaspoorboy Roofing/Siding 5 03-16-2008 11:14 AM
