Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-29-2011, 12:55 AM   #1
metal roofing question.
I have a simple question on steel roofing.
Had a small one added to home for over patio and noticed the screws are in the middle of the flattest areas and not beside the high points.Will i have any problems by not having them beside the higher points or the 1 inch ridges?
Also on the sides, where the gable runs, how close to edge or over should 1st panel go; and is the starting edge on outside to be curved edge or the flat side?
hidden 1 is offline   Reply With Quote
Old 10-29-2011, 06:28 AM   #2
"Nail-Bender"
Post some pictures.
rossfingal
rossfingal is offline   Reply With Quote
Old 10-29-2011, 04:08 PM   #3
here are a few pics.[IMG]file:///C:/Documents%20and%20Settings/Dennis/My%20Documents/2011-10-29%2010.58.38.jpg[/IMG][IMG]file:///C:/Documents%20and%20Settings/Dennis/My%20Documents/2011-10-29%2010.58.38.jpg[/IMG]2011-10-29 10.58.38.jpg 2011-10-29 10.58.38.jpg
metal roofing question.-2011-10-29-10.58.38.jpg   metal roofing question.-2011-10-29-10.59.18.jpg   metal roofing question.-2011-10-29-10.59.44.jpg
Old 10-29-2011, 04:11 PM   #4
on 2nd picture does flat edge go on outside and should it be ou out a tad or level with corner?
screws are where leaf in 1st pic is-between the arches in the flattest area
Old 10-29-2011, 09:47 PM   #5
harry_ho's Avatar
I always leave about 1-1/2 inches hanging over the rakes and eaves. I've never heard of capping installed along a rake like that.
And about the screw placement...I don't think it matters as long as the screws are seated properly. I've always put them right next to the ridges.
harry_ho is offline   Reply With Quote
Old 10-29-2011, 10:46 PM   #6
so its correct to place first panel with flat edge at outside?.its gable on edges.
Old 11-04-2011, 08:07 PM   #7
harry_ho's Avatar
Well, that's the way I've always done it, but I am not a full-time roofer. I have installed probably a dozen metal roofs, and never had a leak doing it this way, though.
I always space the screws along the rakes closer together than everywhere else, too.
If you can get some installation instructions from the manufacturer, it would be a good idea to look 'em over.
metal siding and roofing. leng Building & Construction 3 05-30-2011 12:21 AM
Metal Roofing and Insulation bforrest13 Roofing 6 03-12-2011 09:06 AM
Roofing contract question. SWC11 Off Topic 2 03-17-2010 09:02 PM
Insulation under metal roofing merle Roofing 1 01-11-2010 11:23 PM
rolled roofing or metal rick32 Roofing 3 10-21-2008 03:11 PM
