-   -   metal roofing question. (http://www.diychatroom.com/f9/metal-roofing-question-121667/)
hidden 1 10-29-2011 12:55 AM
I have a simple question on steel roofing.
Had a small one added to home for over patio and noticed the screws are in the middle of the flattest areas and not beside the high points.Will i have any problems by not having them beside the higher points or the 1 inch ridges?
Also on the sides, where the gable runs, how close to edge or over should 1st panel go; and is the starting edge on outside to be curved edge or the flat side?
rossfingal 10-29-2011 06:28 AM
Post some pictures.
rossfingal
hidden 1 10-29-2011 04:08 PM
pics
3 Attachment(s)
here are a few pics.[IMG]file:///C:/Documents%20and%20Settings/Dennis/My%20Documents/2011-10-29%2010.58.38.jpg[/IMG][IMG]file:///C:/Documents%20and%20Settings/Dennis/My%20Documents/2011-10-29%2010.58.38.jpg[/IMG]2011-10-29 10.58.38.jpg 2011-10-29 10.58.38.jpg
hidden 1 10-29-2011 04:11 PM
pic
on 2nd picture does flat edge go on outside and should it be ou out a tad or level with corner?
screws are where leaf in 1st pic is-between the arches in the flattest area
harry_ho 10-29-2011 09:47 PM
I always leave about 1-1/2 inches hanging over the rakes and eaves. I've never heard of capping installed along a rake like that.
And about the screw placement...I don't think it matters as long as the screws are seated properly. I've always put them right next to the ridges.
hidden 1 10-29-2011 10:46 PM
so its correct to place first panel with flat edge at outside?.its gable on edges.
harry_ho 11-04-2011 08:07 PM
Well, that's the way I've always done it, but I am not a full-time roofer. I have installed probably a dozen metal roofs, and never had a leak doing it this way, though.
I always space the screws along the rakes closer together than everywhere else, too.
If you can get some installation instructions from the manufacturer, it would be a good idea to look 'em over.
