Metal Roofing & Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-27-2009, 09:40 AM   #1
Question
Metal roofing & insulation
Check with your metal supplier they seem to know what is best and for what application. I have the same issue and am going to strap the roof with 1x4's just because I don't want to sink a screw into one of the gaps between the old slat boards.
bronco2 is offline   Reply With Quote
Old 09-28-2009, 06:48 AM   #2
Question
I now have another issue. There is no insulation in the roof or very little. What am thinking is to strap with 2x4's and to fill the gap between strapping with 1 1/2" styrospan,the rigid styrofoam panels. My question is do I need to use tucktape on all of my joints.
Old 09-28-2009, 10:20 AM   #3
Commercial Roofing
AaronB's Avatar
Unless your ceilings are cathedral, thsi will not help your building envelope needs at all.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-28-2009, 09:28 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
little or no insulation in Canada?
with the metal id be concerned with moisture condensing on
the metal panel underneath
Tom Struble is offline   Reply With Quote
Old 10-01-2009, 07:51 AM   #5
My ceilings are cathedral to a point. From the end of the rafters up 12' is cathedral, then flat for the remaining 6' of the rafter. There is spray in insulation on top of the flat part of ceiling with no inside vapor barrier. I was just wandering if I ran the styrosan up the 12' if this would help or should I run it all the way to the peak. And the condensation issue should be covered with the nova seal 2 underlay the manufacturer recommended. Please help.
Old 10-01-2009, 07:56 AM   #6
Morning Scuba, You got any ideas for me, or are we waiting for the others to wake up.
Old 10-01-2009, 08:11 AM   #7
I moved your posts to a seperate thread for less confusion
While I have done a few roofs I have never done a metal roof
So I have no input on this one - sorry
Old 10-02-2009, 06:55 AM   #8
Alright then. I have another issue now. Knob and Tube wiring, I will take this topic to the appropriate electrical section though.
Old 10-02-2009, 07:18 PM   #9
Commercial Roofing
AaronB's Avatar
It all depends on your construction details. If youre insulating the attic space to hold heat and humidity in the attic, then this will help your plight. If you're looking to insulate the living space, then you need to insulate on top of the ceiling.
What type of sprayed insulation do you have in the vaulted ceilings?
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 06:48 PM
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing/Siding 2 09-22-2009 09:49 AM
Insulation under Metal roofing. Danimaniac Roofing/Siding 1 05-06-2009 08:00 PM
metal roofing nomoney Roofing/Siding 27 01-12-2009 09:29 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
