Metal Roofing Install - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 10:25 PM   #1
jschaben
Rewards Points: 502
Metal roofing install
After a visit from a tornado over the memorial weekend, it appears we are in the market for a roof. The roof isn't gone, just invaded by several large tree branches so will need a couple of rafters taken care of and three or four sheets of sheathing replaced. Have all but settled on replacing it with a metal roof but have heard a couple of conflicting (or it seems to me) methods of installing the stuff. One is to remove all existing shingles and lay down two or three layers of roofing felt(? maybe they didn't say felt, but some other product) or leave the existing shingles there and just install the metal over them (I'm gonna assume firring strips or something similar to attach them to.
My question is are either or both of these acceptable approachs, and is one preferred over the other or another approach altogether. I have all but zero knowledge of roofing. Patched a few very minor leaks over the with varying degrees of success
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-02-2012, 01:05 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 824
I, personally, do not like going over existing shingles.
Some manufacturers allow for it with a proper slip layer but we prefer to remove all the old crap and get right down to the deck and make sure it is complete and squared away.
You can do both but the only benefit to going over-top of asphalt is saving on dump and removal fees.
Beyond that, there are bunch of rationales for the type of installations.
Old 06-02-2012, 05:11 PM   #3
jschaben
Rewards Points: 502
Thanks for the response. Since we need to replace some sheathing as well as repair some rafters, removing will probably make the most sense. I also heard that laying it directly on some type of underlayment would make it more resistant to hail damage as the metal would have more support than just firring strips.
John Schaben
Old 06-02-2012, 09:23 PM   #4
Rewards Points: 824
Solid decking with help with hail damage butif it is big enough...it's going to show.
Purlins and over deck venting are beneficial for additional moisture control and heat control.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
metal roofing beestarnes Roofing/Siding 2 10-08-2011 05:33 PM
Roofing Material History Roofmaster417 Roofing/Siding 4 09-08-2011 05:49 PM
rolled roofing or metal rick32 Roofing/Siding 3 10-21-2008 03:11 PM
Metal Roofing for Experienced Beginners rezroofers Roofing/Siding 3 06-21-2007 12:42 AM
