Metal Roofing For Experienced Beginners - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-10-2007, 02:54 PM   #1
Metal Roofing for Experienced Beginners
we live in a remote area where there are no local experts on standing seam metal roofing. there are few books available on metal roofing alone: from start to finish and then upkeep. Can anyone point us in the right direction? We have basic construction experience and knowledge. we need info on the entire process from materials and techniques, especially roof opening treatment. Please send info, thanks!!
rezroofers is offline   Reply With Quote
Old 06-10-2007, 05:16 PM   #2
Rewards Points: 180
No, no, no
Post the info here
I need it also
ocoee is offline   Reply With Quote
Old 06-11-2007, 08:53 AM   #3
General Contractor
joasis's Avatar
Visit mbci.com...or simply do a google search on SSR....you don't give a location, so that is the best you will get for now. Doing the SSR is not a DIY project, but you should find tech data available.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 06-21-2007, 12:42 AM   #4
I just installed metal roofing recently. I can offer my findings without a book (the books sure as heck will not have it)
Hot day? count on a few bubbly spots. Of course it is up to you and your tolerance. as long as the seams meet good of course.
tore off old shingles and reroofing with metal?
the rafters will change as you screw it off- different weight and if doubled seams are over rafter, it will pull the old sagger back up (they all do- even a 12 12 pitch over the years has lost some straightness) I found starting in the middle of the run is good for the whole seam, then screw it off however you want to.
that is about all I can think of. Other than these negatves I found it to be amazing cure for older buildings that have moved around a bit (I am in maine- it is as bad as pilgrims ran from in the 1600s) only the idiots stayed behind to fight god himself apparently. Anyway, have fun if you are normally a shingle person, it is very fast to lay it down after the cuts.
bgd73 is offline   Reply With Quote
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
metal roofing nomoney Roofing/Siding 27 01-12-2009 10:29 PM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 10:59 PM
