Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-27-2010, 05:05 PM   #1
metal roofing???
I'm building a small 3' x 8' shed and would like to use a metal roof. Where can I get a sheet of metal roofing? Is there any reason why I shouldn't use it in this application?
Are there any other light roofing option I should consider?
mopowers is offline   Reply With Quote
Old 05-27-2010, 05:26 PM   #2
Shut in w/o Home
seeyou's Avatar
metal roofing???
I'll go out on a limb here and suggest maybe a roofing supply store.
Here's two: ABC Supply, 2710 R Street, Sacramento - (916) 452-7000
5860 Alder Avenue, Sacramento - (916) 383-8311
seeyou is offline   Reply With Quote
Old 05-27-2010, 05:51 PM   #3
Doing This Way Too Long
metal roofing???
Smart Ass!!
Mopowers if you are just looking for cheap rolled rib your local big box also carries it in 12' lengths I believe.
OldNBroken is offline   Reply With Quote
Old 05-29-2010, 05:42 PM   #4
metal roofing???
Thanks for the input and contacts. Sorry to sound stupid, but I've never done this type of roofing before. Can I just screw the roofing directly to the framing? Or do I need to lay down some plywood first? Remember, this is just a small 3 x 8 shed.
Agains, sorry to sound stupid. My hobby is building hotrods, not roofing. So this is new to me.
THANKS again!
Old 05-29-2010, 05:52 PM   #5
Shut in w/o Home
seeyou's Avatar
metal roofing???
THANKS again!
You need either solid sheathing (plywood) or purlins (spaced 1x run perpendicular to the rafters) for the metal to sit on.
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing 2 09-22-2009 10:49 AM
metal roofing nomoney Roofing 27 01-12-2009 10:29 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Metal Roofing for Experienced Beginners rezroofers Roofing 3 06-21-2007 12:42 AM
Lathe metal roofing? Stan ETenn Roofing 8 02-18-2005 03:51 PM
