Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-21-2010, 02:19 PM   #1
metal roofing
i just had a metal roof put on my new home and am getting a lot of moisture on inside of osb, had gable vents and ri soffitt vents wa s told both are to much,what is my answer to stop so much condensation?need help pleqase answer thank you,was told to plug gable vents to let air in threw soffit and out ridge,it helped but still doing it,what can i do thank you
bowhunter is offline   Reply With Quote
Old 01-21-2010, 05:52 PM   #2
MJW
metal roofing
Was the metal applied directly to the OSB?
MJW is offline   Reply With Quote
Old 01-22-2010, 01:00 AM   #3
jlhaslip's Avatar
metal roofing
metal roofs will 'sweat'.
the roof sheathing should have had black paper and strapping as a ventilation route.
jlhaslip is offline   Reply With Quote
Old 01-22-2010, 01:17 AM   #4
Tom Struble's Avatar
metal roofing
do you have any vents,venting directly into the attic? you need to get a handle on moisture coming from the living space that is making its way into your attic
Tom Struble is offline   Reply With Quote
Old 01-22-2010, 06:34 AM   #5
metal roofing
yes metal was put on over black paper and osb ,that is how home depot told me to install it,yes got soffit vents and gable vents but gables are plugged,it helped alot but not all togeather,please help thank you
Old 01-22-2010, 11:02 AM   #6
jlhaslip's Avatar
metal roofing
what pitch is your roof?
Old 01-22-2010, 04:03 PM   #7
MJW
metal roofing
Go back to Home Depot and tell them they are NOT Contractors and should NOT be giving advise!! Then, ask them what they are going to do, to fix your problem.
IMO, the entire roof needs to be redone correctly by a professional.
Old 01-24-2010, 12:34 AM   #8
Moderator
metal roofing
The National Roofing Contractors Association (NRCA) recommends a layer of asphalt-saturated felt between the insulation layer and standing seam metal roof to provide a drainage plane in buildings with high potential for condensation. The NRCA Roofing and Waterproofing Manual recommends using a vapor retarder with a permeation rating of 0.5 perms or less in certain climate zones. When installed with sealed (taped) joints, highly water-resistant XPS insulation eliminates the need for these additional layers (see Figure 7). From: http://www.roofingcontractor.com/CDA...00000000484938
http://docs.google.com/viewer?a=v&q=...oCq-P91xd-Qiaw
Your attic venting isn’t enough or the heated air from the living space below is more than the venting. http://www.rd.com/how-to-seal-attic-...icle18158.html
Homework: http://www.fureyco.com/content/image...ng_The_Air.pdf
http://www.airvent.com/homeowner/pro...it-specs.shtml
http://www.buildingscience.com/docum...on?full_view=1
Stack effect: http://www.wag-aic.org/1999/WAG_99_baker.pdf
Be safe, Gary
Clothes taking longer to dry?
1927 Metal porch roof/Deck 4'x6' (EDPM or Rolled roofing). greenhornet Roofing 2 09-22-2009 10:49 AM
Metal Roofing sfd2100 Roofing 6 08-28-2009 02:41 AM
metal roofing nomoney Roofing 27 01-12-2009 10:29 PM
Metal Roofing for Experienced Beginners rezroofers Roofing 3 06-21-2007 12:42 AM
Lathe metal roofing? Stan ETenn Roofing 8 02-18-2005 03:51 PM
