| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Terminate Shake Tiles over the Gable Fascia
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The shake panels are terminated by bending over the gable fascia at approximately 2 inches. Place the shake cap over the gable aligning a profile in... Read More »
How to Fasten Metal Tile Roofs
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
How to Lay a Full Course of Metal Roofing
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Starting at the very first full course from the ridge, lay two panels simultaneously. The second course is used to accurately space the joints of the... Read More »
How to Frame the Roof Ridge
by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Where the ridge is to be ventilated and the coursing is less than a full tile, a one inch board is laid parallel with the ridge on each side... Read More »
How to Install Metal Roof Tiles in Transition Areas
by Expert Village
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. In this instance a minimum two courses of lower roof panels are laid through. If possible with continental tiles, lay it out so that the lower part of... Read More »
