Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-23-2009, 11:37 AM   #1
Metal Roofing
I am beginning to plan my roofing project for this spring / summer. I want to go with a metal roof.
Is there a product that is suitable for installation over a deck which has 24" OC trusses below it? Most of the stuff I've seen so far wants 16" OC.
Reilley is offline   Reply With Quote
Old 01-23-2009, 07:11 PM   #2
Pro Slate Roofer
tinner666's Avatar
Metal Roofing
Here you go, http://permanentroofing.com/
Frank
tinner666 is offline   Reply With Quote
Old 01-24-2009, 10:40 AM   #3
Metal Roofing
Thanks. I did come across that link yesterday.
I'm actually looking at panel roofing, such as the offerings from Midwest Roofing through Menards.
I have 5/8" or 1/2" decking. I'm just wondering if the panels need to be screwed through the decking into the trusses or if screwing into the deck is sufficient.
Old 01-24-2009, 11:44 AM   #4
Metal Roofing
Metal panels are typically screwed to the deck, not structural members, so you should be fine as long as the decking is sound.
rustyjames is offline   Reply With Quote
Old 01-24-2009, 11:44 PM   #5
Tom Struble's Avatar
Metal Roofing
do you have any experience installing a standing seam roof?
make sure you get an installation manual from the manufacturer.
if you have a complicated roof or any roof penetrations they have to be handled correctly.A standing seam roof is durable and long lasting as long as the details are done correctly.Done wrong and you will have an expensive disaster on your hands
Tom Struble is offline   Reply With Quote
metal roofing nomoney Roofing 27 01-12-2009 10:29 PM
rolled roofing or metal rick32 Roofing 3 10-21-2008 03:11 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Metal Roofing for Experienced Beginners rezroofers Roofing 3 06-21-2007 12:42 AM
Lathe metal roofing? Stan ETenn Roofing 8 02-18-2005 03:51 PM
