Metal Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-25-2008, 01:53 PM   #16
the roofing god's Avatar
Send a message via MSN to the roofing god
grace is just an epdm with glue to attach,the asphaltic ice & water shields would/could cause a problem over time
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 03-25-2008, 02:30 PM   #17
obsessed with roofing
coolflatroof's Avatar
to AaronB
the thing about epdm and roof cement is that epdm moves (expands/contracts) while roof cement hardens and does not move, therefore the bond between the two breaks quickly.
to roofing
grace ice and water IS asphalt based! it is not epdm. On a recent IB job we did, the sky-lights were wrapped in grace I&W and my heat welder briefly touched it. It quickly melted all over the tip of the welder and started dripping a little bit on the membrane, and then took some time to clean it off. Trust me , it is definitely asphalt based.
coolflatroof is offline   Reply With Quote
Old 03-25-2008, 05:06 PM   #18
Ice and Water Shield is a bituthane polymer asphaltic based product.
Yes, it melts from a Liester, quite easily even from the hot air flow, let alone touching the nozzle to it. It shrinks and opens up voids almost instantly.
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-26-2008, 12:41 AM   #19
Commercial Roofing
AaronB's Avatar
Ok, well all asphaltic products are not compatible with EPDM but do not eat the EPDM like I hear so often.
I do not think that the grace over epdm would be a compatibility issue, rather a disbondment issue, thereby offering little to no protection that would not otherwise be afforded by the EPDM.
Not all roof cements will harden. Yet all roof cements are incompatible with EPDM.
Also, a MF,FA EPDM will not likely expand and contract so much as to break a bond of roof cement at a penetration. (I would still not use it on rubber) The solvents in roof cements WILL degrade the rubber though.
Incompatible ALSO because of membrane degredation due to the solvent content. How's that?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-26-2008, 12:48 AM   #20
ok,been a looong time since I`ve bothered with grace,since it 1st came out,anyway-tend to prefer the gaf anyway,and usually use mod bit rather than the epdm,unless it`s a spec.
Lathe metal roofing? Stan ETenn Roofing/Siding 19 06-18-2013 07:48 PM
5v crimp metal roofing? wkraft Roofing/Siding 12 05-16-2010 08:24 AM
metal roofing nomoney Roofing/Siding 27 01-12-2009 10:29 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Metal Roofing for Experienced Beginners rezroofers Roofing/Siding 3 06-21-2007 12:42 AM
