Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-06-2009, 02:20 PM   #1
waveblasternutcase
Default Metal Roof Screws Leaking
We have a metal roof that is about 10 years old and it was installed by the previous owner. Because of that, the installer will not honor his installation warranty, just the manufacturer's. We discovered a few leaks in the roof and have determined that they are coming from some of the screws on the roof. these are self tapping screws with rubber bushings. the installer wants $1000 to do the job since they must remove the ridge cap, install anchors, replace the ridge cap and then check the screws.
anybody with experience in this area? is this something that the everyday joe could do? i taped a socket wrench to a broom handle and was able to tighten some of the lower ones...
WBNC
WBNC is offline   Reply With Quote
Old 11-06-2009, 06:58 PM   #2
Pro Slate Roofer
Exposed screws need maintenance. They're gonna let water in around them, even if you can't see it. Until the wood rots in those spots.
Every few years, I believe you'll need to go up 1 screw size and replace them all.
Never use the system myself.
tinner666 is offline   Reply With Quote
Old 11-06-2009, 11:52 PM   #3
I've got a metal roof with screws like you describe.
The roof should have been installed over a waterproof membrane, like felt. If it's not, then it's not on right.
If there's a small leak, it ought to drip off (or worst case down) the screw and hit the felt.
It seems like it should take a long, long, time before the very small amount of water could get past the felt. Mine shows no signs of water on the underside of the roof decking after at least 5 years.
The point of failure is the rubber gasket. Just replace the screws that leak, and don't screw them in so tight.
pyper is offline   Reply With Quote
Old 11-07-2009, 09:48 AM   #4
Pro Slate Roofer
Tightness can make some difference. Not much. Listen to the roof installed with exposed fasteners. You can hear it shifting as the metal heats in the morning and trying to find a way to expant between the screws. The metal loosens the screws with all it's movement. The holes around the screws elongate to accomadate the movement.
5 years is a good run without leaks. Bck out a few screws and see if the wood shows signs of dampness yet.
That's why real metal roofs have expansion built into them.
http://www.albertsroofing.com/Tin%20...to_gallery.htm
Old 11-09-2009, 11:52 PM   #5
tomstruble's Avatar
those kinda of roofs are usually meant for open purlin ag buildings
not houses
tomstruble is offline   Reply With Quote
Old 11-10-2009, 12:11 PM   #6
JDM
Tightening the screws may not actually help, in fact it can make it worse. If you overtighten the screws it can cause them to leak. You need to remove the screws that are leaking now and replace them with #14 oversized roofing screws. You can do the job yourself.
JDM is offline   Reply With Quote
Old 11-10-2009, 12:20 PM   #7
waveblasternutcase
the ones that i can reach i have tightened just a bit. i did not want the busings to mushroom...
Old 11-11-2009, 04:09 PM   #8
Originally Posted by tomstruble View Post
those kinda of roofs are usually meant for open purlin ag buildings not houses
Screw down metal roofing is becoming very common in the South. It's commonly put over old roofs. In new construction they usually put sheathing on the roof first. Some installers put purlins on top of the sheathing (or old roof) and some don't.
FWIW, my shed has had "5V" metal roofing for 15 or more years (it was there when we bought it). It's open on the bottom, and as far as I can see there are no leaks (I just checked -- the remnants of hurricane Ida just dropped 4 or more inchees of water on us, so if there was a leak it would be easy to spot). It's not even put on with screws, but nails with little neoprene washers.
Old 11-13-2009, 03:09 AM   #9
tomstruble's Avatar
just because its becoming common dont mean its the way to do it
the more of these roof you see the more problems your going to see with screws leaking
think about it every one of those thousands of screws have to seal perfectly ,the roof on your shed is the place for that product
a conceled fastener roof for a house imo
Old 11-13-2009, 12:19 PM   #10
a concealed fastener roof for a house imo
You make it sound like there's no margin of error on installing the screws.
The fact that my shed, built probably 20 years ago by guys who didn't know what they were doing, still doesn't leak even after 4 inches of rain, suggests otherwise.
Concealed fasteners sound like they'd be superior, but the screw-through systems seem to be fairly robust. How much more does the material for a concealed-fastener roof cost? It's not like we're going to change anything at this point though, but I'm curious. Actually, if I did get a leak from a screw I would probably be tempted to put a dab of silicon caulk on the screw head.
Old 11-13-2009, 07:05 PM   #11
Pro Slate Roofer
"Concealed fasteners sound like they'd be superior, but the screw-through systems seem to be fairly robust. How much more does the material for a concealed-fastener roof cost?"
I don't know. Doing residential, I've never had reason to price the exposed fastener system. I'm more into the 'century' roof.
I do get many calls to repair/recaulk/rescrew that type though. Never bothered to bid one. I've been under them often and it's a neat sound to her as the sun starts warming those panels. Little twings, twangs, and other noises abound as the metal tries moving under the strain of expansion. Pretty neat!
Old 11-13-2009, 11:15 PM   #12
I'm under mine all the time as it heats and cools and it doesn't do that. I wonder what the difference is.
More On This Topic
How to Frame the Roof Ridge
How to Frame the Roof Ridge by Expert Village
Hi, I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Where the ridge is to be ventilated and the coursing is less than a full tile, a one inch board is laid parallel with the ridge on each side... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. All panels are fastened through the front lip with a minimum of four fasteners per panel. Building codes or special conditions may require more, please... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. Barrel cap trim is installed from the bottom up course to course with the panels. Install the end disc, position the first cap on the rig with the rear... Read More »
I'm Tom Shean and today on behalf of Expert Village I'm going to show you how to install a metal roof. The valley flashing is laid between two valley battens and fastened through the top flange. Where the valley terminates at a fascia, the valley... Read More »
Patching a flat roof may not seem like much fun and you may be tempted to call in the experts. There are several roofing companies that only do flat roofs because of the lower amount of work involved. But you can patch your own membrane roof if you have... Read More »
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing 2 09-12-2008 10:51 PM
New 1yr Townhome with Leaking Roof! sijunk Roofing 9 08-08-2008 05:50 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 08:17 AM
1928 metal roof rusting basilbiko Roofing 5 07-19-2006 01:57 PM
Help- leaking flat roof, alum?metal? xoroniox Roofing 1 04-24-2006 01:03 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
