Metal Roof Is Rusting - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2010, 12:46 AM   #1
Metal Roof is Rusting
I have a metal roof that is rusting. Actually two of them on two different houses I own. One roof appears to have an aluminum roof coating and the other one is painted red. Both need some kind of maintenance as they both have rust but aren't leaking yet.
What is the best way to fix this issue? I was thinking of using a power washer to remove the rust, waiting a day to dry and then using Henry aluminum roof coating? Any better ideas?
Thanks.
jonathan03 is offline   Reply With Quote
Old 03-15-2010, 08:06 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I doubt washing will remove rust. It might knock off some scale. If there are any leaks, the power washer should find them. Best spray away from the seam, not towards them.
tinner666 is offline   Reply With Quote
Old 03-15-2010, 11:05 AM   #3
Commercial Roofing
AaronB's Avatar
Depending on the state of the rust, you may be able to use a rust-inhibiting primer after the power washing and drying to stop the rust in its tracks.
There are various brands available. Talk to your local roofing supplier or paint supplier to find which will work best for your situation.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-15-2010, 12:38 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
aluminum coatings on a steel roof could also be causing a problem
Tom Struble is offline   Reply With Quote
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
New Metal Roof agrace Roofing/Siding 2 08-24-2008 11:27 PM
