Metal Roof Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-23-2010, 02:07 PM   #46
mem
Rewards Points: 156
Originally Posted by OldNBroken View Post
No, not really, there are a LOT more hacks in this field than competent installers. But it does sound like you have a very reliable contractor and the main thing we stress for ANY roof system is " It's only as good as the person installing it."
We just pointed out some things that we have concerns with..screws, clips, clip spacing. As long as he is there to address any possible issues in the future you have no worries.
Post some finish and detail pics if you feel like it. They are always good for future references on these forums.
No question about the hacks out there! I know it's not advisable to get too many estimates on a project, but I had to interview maybe 18 or 20 contractors just to get a few viable bids. I had to dismiss one after another before they were even out the door. Everything from obvious ignorance of the trade (even I knew more than some, if you can believe it), to used car salesman techniques.
Anyone for some humble pie? Seems I have made some mistakes earlier. I had my memory jogged and there were two kind of screws used up there. I found a few of the others laying about. They look like the real deal. And I'm not certain of the pop rivet material either. They are not magnetic so they could be stainless or aluminum, They are kinda shiny tho, I can't tell.
Maybe I'll sleep a little better tonite. And I will most certainly post more pics when I can. Gotta lose a little snow first.
mem is offline   Reply With Quote
Old 12-23-2010, 02:12 PM   #47
Tom Struble's Avatar
Rewards Points: 2,002
rivit look like ss,screws for the clip should
have a head like the drill point you showed earlier
Tom Struble is offline   Reply With Quote
Old 12-23-2010, 02:16 PM   #48
mem
Rewards Points: 156
How can you tell it's stainless? The sheen? I thought the drill point would evacuate too much wood and reduce the holding power.
Old 12-23-2010, 03:34 PM   #49
head not tip on the screw,rivet's just a guess but it looks like a typical ss metal roof trim type
Old 12-23-2010, 04:36 PM   #50
Doing This Way Too Long
Rewards Points: 532
Looks like SS to me also. Aluminum will have either aluminum or steel mandrel and that mandrel is SS. Looks like you are fine there. As far as screws, it's all about pullout and shear strength. Regular deck and drywall screws have decent pullout but terrible shear strength. There are many options out there, only way to know is to test it yourself.
OldNBroken is offline   Reply With Quote
Old 12-23-2010, 05:52 PM   #51
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
As for your caulk question. I have little experience with it. Maye use 10-12 tubes a year, sometimes a bit more on counter-flashing. I form my own penetration panels to avoid using it. Where any over-lap, in shingle fashion, I put a bead or two under them to seperate them and short circuit any capilary action. Most any brand will work for that.
tinner666 is offline   Reply With Quote
Old 12-23-2010, 06:01 PM   #52
Pro Slate Roofer
tinner666's Avatar
For instance, scroll down to 'Steel Roof Pipe Collar', 5 photos. http://www.rooferscoffeeshop.com/pho..._list.asp?u=30
We did stop using those collars. GC spec'd those when Oakey quit making the 'Lead-Head' collars.) The ABS are much easier to repair.
In the pix, some caulk was used to seperate the panels.
At my ridges, with boxed panels, no caulk is required, nor used. I use the SS rivets when I need to use rivets.
Old 12-24-2010, 10:36 AM   #53
mem
Rewards Points: 156
DUH! Someday I'll get the hang of this reading comprehension thing. That little funnel shape under the pancake head is a bit too large for the hole in the clip tho, and it keeps the screw from fully seating by about a 32nd. At least it's got a wood thread.
Old 12-24-2010, 10:51 AM   #54
mem
Rewards Points: 156
I'm pretty well certain that they're SS now too. Do you test for pull out as simply as screwing down the clip and then try to yank it out with a prybar? What about shear strength? Try to just break it off?
Old 12-24-2010, 11:16 AM   #55
mem
Rewards Points: 156
Tinner, I checked out your album and that looks like the perfect way to handle the vents. Do you just crimp the ribs of the shingle panel in with those of the adjacent panels? Does the extra thickness cause any difficulties? I'll get some pics of how it was handled on this roof later. They don't look right to me--probably laughable to you guys. No doubt they took the easy way.
What caulk do you prefer to use?
Old 12-24-2010, 11:22 AM   #56
mem
Rewards Points: 156
Just a quick shout to say thanks and I wish you all the best of Holidays and a prosperous New Year!
mem
The Following 2 Users Say Thank You to mem For This Useful Post:
tinner666 (12-24-2010), Tom Struble (12-24-2010)
Old 12-24-2010, 11:45 AM   #57
Pro Slate Roofer
tinner666's Avatar
I just hand form any panel I need. Look at my copper roof albums, or my website. I have no preference in caulk, except BlackJack Neoprene for EPDM, and counter-flashing, I also use GeoCel for others apps.
I think I figured out what TItebond is. I do a lot of repairs on metal that some monster sticking caulk, usually white that i have to cut loose.
My philosophy is this. If the detail work is lacking, NO amount of caulk will last long term. If all the detail work is spot-on, Elmers will be fine.
Here's an underside view of my box-folded panels.
The next pic is tin, but the panels were extended full lenght past the sky-light eliminating the corners No solder or caulk needed on my corners.
Metal Roof Questions-box-folded-panels.jpg   Metal Roof Questions-solution5.jpg
Old 12-24-2010, 11:52 AM   #58
Pro Slate Roofer
tinner666's Avatar
24 ga, Steel Chimney panel. You can see how the field panels were cut on the right, then on the left is a filed formed side panel.
I have no understanding of cutting a field panel flush with a penetration. How can caulk perform like an uncut panel?
The Following User Says Thank You to tinner666 For This Useful Post:
Old 12-24-2010, 12:04 PM   #59
Pro Slate Roofer
tinner666's Avatar
Now, before we locked that panel to the left side, we ran about 4 beads of caulk across the bottom. It's only purpose is to short-circuit capilary action. Sometimes, we just make skinny, or wider panels to go in front of apenetration, corner to corner, box fold them in place and completely eliminate the caulk issue entirely. Like this. A dab of gutter sealer was used in the fold just to keep any moisture from getting in and freezing, as unlikely as that sounds. About 1-1,000,000 chance.
And sometimes like this, and solder the very bottom, inside of corner.
Old 12-24-2010, 12:08 PM   #60
Pro Slate Roofer
tinner666's Avatar
As you can see, there are many ways. Some are right, some are wrong. Some of my methods are still evolving.
Shed Roof Questions jobondur Roofing/Siding 1 10-04-2010 10:52 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Metal Roof Estimate supton Off Topic 5 04-17-2010 03:08 PM
questions about wood shake roof oraph Roofing/Siding 4 10-26-2006 05:10 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
