Metal Roof Questions - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-21-2010, 10:51 PM   #16
mem
Rewards Points: 156
Originally Posted by tomstruble View Post
''joggle cleat''is one manufacturers name for a z shape piece that trims and pans get locked in to
first clip should be no more than 6'' from the end of the panel,1 screw per bracket
Tom, is this the "joggle cleat"? They called them "Z" mould. They are 26 ga and used to secure the ridge cap and to flash the skylights. Note the nice protective film, I wonder how much of that they forgot the remove!
The first clips are no where near the ends of the panel.
mem is offline   Reply With Quote
Old 12-21-2010, 11:46 PM   #17
mem
Rewards Points: 156
Originally Posted by OldNBroken View Post
Yes, only need two screws per clip, but what type of screw did they use? Yes, that clip is the weak link in your system.
Regardless of the system or clip placement in the field, it is standard practice to put one clip <6" from eave and ridge and the next clip within 24" of that clip. In the field 36-42" is usually comfortable.
As I said about your eave detail. It would be nice if more installers would put a little more into their details but, unfortunately the majority either don't know how or don't care.
OldNBroken, here is a shot of the screws they used, looks like #8's.
The foto in my last post shows no clips anywhere near 24" from the end, let alone 6". These fotos show how they spaced the clips in the field. In the second one, the first two clips look like they're 8 or 9 feet apart.
I appreciate all your help guys, I'll have more questions tomorrow-getting sleepy.
Old 12-22-2010, 12:18 AM   #18
Doing This Way Too Long
Rewards Points: 532
Am glad you didn't show us a picture of deck screws or something with no shear strength otherwise your roof may have looked like this...
I didn't know this was a metal deck they were going over.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Tom Struble (12-22-2010)
Old 12-22-2010, 08:13 AM   #19
Tom Struble's Avatar
Rewards Points: 2,002
no thats a z closeure,i probably shouldn't have used the term as it may just be specific to one particular manu.Those drill point screws are generally used for attaching the clips to metal framing,i wonder if having a drill point reduces the holding power in roof sheathing?
Tom Struble is offline   Reply With Quote
Old 12-22-2010, 09:06 AM   #20
mem
Rewards Points: 156
OK Tom, I got off my butt and googled joggle cleat, and now it's clear. Looks like they would especially be used to attach the panels in the valleys.
Good point on the screws, no pun intended. Moreover, the threads are not cut very deep like you would find on a wood screw either. That's bothersome.
Old 12-22-2010, 09:09 AM   #21
mem
Rewards Points: 156
Holy Moly on the wind damage! I hope that's not in my future.
Old 12-22-2010, 09:22 AM   #22
Rewards Points: 532
That's why I asked about the deck because those are metal screws. Wood screws have a much courser thread. Min we use is #12
This was a combination of clip failure and half the clips were installed with drywall screws. some of the clips at the perimeter were intact but straightened out vertically by the wind getting under the panel.
Old 12-22-2010, 09:37 AM   #23
mem
Rewards Points: 156
No, it's not a metal deck. All brand new OSB installed by them, 7/16" on 16" centers. I went with the 26 ga instead of the 24 ga because the panels were going on a solid deck.
The screw holes in the clips are nearly a quarter inch in diameter and could easily accommodate a #12 screw.
Old 12-22-2010, 10:23 AM   #24
clip spacing may also have a part in the oil canning,but i'd want the clips space way closer and accept the oil can
usually after the finish weathers somewhat,it usually becomes less noticeable,the caveat is as long as the metal isn't kinked which i believe could eventually crack over time
Old 12-22-2010, 10:25 AM   #25
mem
Rewards Points: 156
OK OldNBroken, now I'm getting scared. Now let's see if I can get a full blown coronary! Am I understanding proper rake treatment?
This drawing illustrates how I expected the rake detail to be handled.
ExpectedRakeEdgeDetail.pdf
And I learned from this site that this detail is fully acceptable as well, if not preferred.
LearnedRakeEdgeDetail.pdf
But, alas, this is how it was ultimately done.
AsInstalledRakeEdgeDetail.pdf
Seems to me that the protection afforded by the standing seam concept has been eliminated at every rake. Also, as on the drip edge, there is no continuous (wind?) cleat installed.
Old 12-22-2010, 10:33 AM   #26
....wow...that ain't right
yea typically the eave detail is not used on a screw down ''corrugated'' type panel,but on a standing seam panel its the standard detail
Old 12-22-2010, 10:45 AM   #27
mem
Rewards Points: 156
I presume you are referring to the AsInstalled drawing Tom.
What's your take on the other three methods? Are any or all acceptable in your book?
How do you treat the rake detail?
Old 12-22-2010, 12:16 PM   #28
mem
Rewards Points: 156
Yes, mine is 180 degree, mechanically crimped standing seam with "no exposed fasteners". I suppose the visible pop rivets they used to secure the ridge cap and skylight flashings are not "exposed fasteners". Say what?!?
Are pop rivets even feasible to use up there?
Old 12-22-2010, 12:43 PM   #29
id say either method that leaves the pan intact and fold around and locks in to a trim is as good as it gets
the rivets are sometimes necessary on exposed trims but they are usually made from stainless steel,care needs to be taken tho,as the trims move Ive seen them actually cut right thru rivets and back out screws
That's why an annual inspection is a good idea
metal roof if done right can give many years of trouble free service,done wrong they can be ''impossible'' to fix
Old 12-22-2010, 01:34 PM   #30
mem
Rewards Points: 156
The rivets are painted to match the roof, a nice touch I thought. I'm not sure, but I believe they are aluminum which, in itself, is problematic. If indeed aluminum and installed in the steel roof I suspect they will corrode away before they get a chance to be cut thru.
What do you use in these instances?
Shed Roof Questions jobondur Roofing/Siding 1 10-04-2010 10:52 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Metal Roof Estimate supton Off Topic 5 04-17-2010 03:08 PM
questions about wood shake roof oraph Roofing/Siding 4 10-26-2006 05:10 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
