Metal roof questions
This is not a project I will be attempting on my own but I’d like to educate myself on the subject as much as possible……
I have a small 1.5 story 1920’s bungalow with your run of the mil gable roof and a small front overhang over an enclosed porch. The old 3 tab shingles are shedding grains at an alarming rate and are starting to curl up. Ventilation is an issue with this house so I’m sure the shingles have suffered for that but I’m slowly renovating the already finished attic and addressing this. I haven’t detected any leaks but I think I’m on borrowed time. I really like the look of those metal roofs with the raised “ribs” (standing seam?). You see a fair amount of them around here, presumably because this is snow country I guess……. -Do these roofs actually have an advantage in snowy areas such as dealing with ice dams and excessive snow buildup? Or is better insulation/ventilation still the answer to that regardless of roof type? -Does a metal roof help keep the living space cooler? I would think shiny smooth metal would be more reflective of the sun’s energy than shingles made of asphalt but I’m no expert. -Does a metal roof use a ridge vent? Sorta hard to tell from the street. House currently has 4 square ridge vents and that’s it. -Can rigid foam board be installed under the metal roof to increase R value? -As installed, which roofing system weighs more? Standing seam metal or architectural shingles? I only have 2x4 rafters so I figure the less of a load on them, the better. Sorry if my questions sound stupid, lol. Thanks for any info. |
Post some pictures.
How steep is the roof? rossfingal |
Where in upstate NY? |
[QUOTE-Do these roofs actually have an advantage in snowy areas such as dealing with ice dams and excessive snow buildup? Or is better insulation/ventilation still the answer to that regardless of roof type?
They do not ice damn when installed properly. That being said, you should correct the heat loss/insulation issue in conjunction with any new roof. ][/QUOTE] A metal roof can reduce the leaking that occurs due to ice damming but it will not prevent ice dams from forming. In some cases it may add to the ice dam formation. Metal Roofs and Ice Dams As WOW said, correct the heat loss/insulation issue first. |
The lack of penetrability on the metal keeps the water from backing up the metal and getting into the roof assembly and home. |
http://i252.photobucket.com/albums/h...smallhouse.jpg Quote:
Buffalo area. In the end I still may go with asphalt shingles if the cost for a metal roof is way higher. Any idea how much more a metal roof usually costs installed than architectural shingles? |
Cost totally depends on your area. For us metal is about double the cost when you include all the screws, flashings, strapping and what not.
Go and ask your Styrofoam insulation question in the Insulation Forum. Probably get more answers there.
Cost is usually double to triple. The problem is finding a competent installer. Most are just asphalt shingle installers jumping on the metal roof bandwagon without any sheet metal experience.
Another option is to cover the lower eave with metal and the rest of the roof with standard shingles. Pictured here; http://www.roofingcontractorreview.c...hield1-46.html Again, you need a competent sheet metal roofer to install. |
When you do your roof, definitely look into insulation and changing the dynamics of your insulation schedule. |
Where near Buffalo are you? I just had a metal roof installed and am pleased with the contractor. I know he does work as far north as Orchard Park. Let me know if your interested and I'll pm his contact info.
To the mods, please remove if my post is not allowed. |
-Do these roofs actually have an advantage in snowy areas such as dealing with ice dams and excessive snow buildup? Or is better insulation/ventilation still the answer to that regardless of roof type? They can shed snow more quickly and also be more resistant to leaks due to ice dams. But ice dams are indeed more about ventilation and insulation. Also, metal roofs can be damaged by ice dams, especially around valleys.
-Does a metal roof help keep the living space cooler? I would think shiny smooth metal would be more reflective of the sun’s energy than shingles made of asphalt but I’m no expert. There are metal roofs with reflective pigment in the paints. Light colors will do the same thing. Some metal roofs have a small space between the metal and the roof deck and that can help as well. Additionally, they do shed gained heat quickly. -Does a metal roof use a ridge vent? Sorta hard to tell from the street. House currently has 4 square ridge vents and that’s it. Most metal roofs can be installed with a ridge vent for exhaust. You then need soffit vents for intake. Good attic ventilation helps with a lot of things especially energy efficiency and avoiding ice dams as well as condensation issues. -Can rigid foam board be installed under the metal roof to increase R value? Very rarely will I ever suggest doing this. There are risks associated with installing metal on foam and also insulation is usually best placed on the attic floor. -As installed, which roofing system weighs more? Standing seam metal or architectural shingles? I only have 2x4 rafters so I figure the less of a load on them, the better. Standing seam will weigh from 70 to 140 pounds per square usually. The low end will be aluminum. Shingles weigh from 275 to 425. I hope this helps. |
Todd Miller is here...?
Welcome Todd. Good to see you. :thumbsup: |
Haha, I think we both get around. :)
Depending on the materals used you can get it colored, with a 75 year warrenty againt rusting.
I've seen many standing seam roofs that are 100 years old and if they were maintained are still fine. Just do a key word search on metal fooring there's hundreds of sites to look over for more info. I've noticed a lot of homes in VT, Up state NY and NH, going back to metal roofing. |
| All times are GMT -4. The time now is 07:59 AM. |
