Metal Roof Or Plastic ? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-10-2011, 07:26 PM   #1
Rewards Points: 1,062
metal roof or plastic ?
people,
have an old shed - has old rusty metal roof- 3'x 14' ribbed galv steel. Should I switch to Home Depot "plastic" (also 3'x14'), or go with same steel sheet? I walk on it often (to sweeep twigs/leaves). Would plastic crack/shatter? Also, if I go with plastic, when I hammer in the alum nails with rubber washers, do I need to pre drill?
Thanks!
noquacks is offline   Reply With Quote
Old 07-11-2011, 06:12 PM   #2
Maybe someone will reply with advice/opinion............I still have time for this anyway.....
Old 07-12-2011, 07:59 AM   #3
Rewards Points: 252
Unless it is rusted through I would paint it. Plastic would not be a good walking surface, depending on what is underneath of it (aka is there any sheathing). You'd probably have to pre-drill the holes, and I would use screws instead of nails.
shazapple is offline   Reply With Quote
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
New Ven Through Existing Metal Roof bmurphywa Roofing/Siding 2 05-20-2009 10:37 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 10:00 PM
