Metal Roof Patching - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-24-2010, 11:38 PM   #1
Metal Roof Patching
I am a college student that is a member of the Engineers without Borders organization. I, along with a groups of other students, are going to Guatemala this spring to install a solor electric system for a school in the mountainous highlands. The school was built with a corrugated metal roof and we need to put 1" hollow tube braces through itfor the solar panel mount. Cutting the holes and installing the solar mounting structure will be the easy part but im having a hard time coming up with good long lasting soution to patching holes around the 1"HT. I am a mechanical engineer so i dont know much about the roofing. I have attached a picture of the roof so you can get an idea of what it is. Thank you for your help. Our final design is due this week so any input would be greatly appreciated.
adamsjd is offline   Reply With Quote
Old 01-24-2010, 11:52 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
this help?
http://www.hartandcooley.com/Librari...hing.sflb.ashx
Tom Struble is offline   Reply With Quote
Old 01-25-2010, 12:10 AM   #3
I looked at some boots similar to those(smaller of course) but the problem is that they are square tubes and relatively small for what is out there. mose of the boots for sale are for things such as 3" vents and chimneys. There is also a bit of cost involved in such items. From what i saw they are around $50 per boot and we would need several of them. Its going to be hard to justify spending a few hundred dollars of teh project budget on fixing a roof that we drilled holes into. Is there any sort of material or high strength/durable compound that could acheive this at a lower cost? I have heard things about a product called eternabond... is that something that would work or is that meant more for only flat surfaces? Thank you again.
Old 01-25-2010, 06:57 AM   #4
oh, i have used eternabond and it would be a good product for your application
just make sure your surface is clean and dry and use a roller to seal it to the surface,some porous or dirty surfaces may need a primer
email them,they may be able to help you design the fittings you need
it's a great product but not cheap
Tags
corrugated metal sheet
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
What kind of paint to use on a continuous metal roof? TitaniumVT Painting 6 12-23-2009 08:33 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
plumbing vent flashing on metal roof??? red86yota Roofing/Siding 14 02-09-2009 11:40 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
