Metal Roof For Mobile Home - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2012, 10:57 AM   #1
Solutions (handyman)
Rewards Points: 362
Metal roof for mobile home
Roof is currently a 4/12 pitch with asphalt shingles. Client is thinking about a metal replacement. If they decide on metal, should strapping be installed or is a weather guard mambrane then the metal screwed directly to the sheathing okay? Opinions are welcome. Thanks.
Mark Harvey is offline   Reply With Quote
Old 07-22-2012, 11:05 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Depends on the manufacturer.
Direct to deck is acceptable in many cases as long as there is a slip layer as you must protect the metal from scratching from the underside.
An over deck vent would be helpful if the venting and insulation layers are not sufficient and you are loosing a bunch of heat resulting in rapid melting.
Old 07-22-2012, 07:14 PM   #3
Doing This Way Too Long
Rewards Points: 532
Whatever you decide, just remember you are only allowed one roof on a mobile home. Gotta tear the old shingles off.
And, no, you do not need batts. 30# felt is adequate for underlayment.
OldNBroken is offline   Reply With Quote
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 04:51 PM
Replacing shingled roof with metal roof myminpins Roofing/Siding 3 06-26-2011 10:43 AM
metal roof on m0bile home hoodrunner365 Roofing/Siding 3 02-10-2010 02:20 AM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 06:51 PM
