-   -   Metal roof leaks (http://www.diychatroom.com/f9/metal-roof-leaks-5366/)
Cowchip500 12-13-2006 02:05 AM
Metal roof leaks
We have a horse barn with a tin-metal roof that's still leaking after putting Snow-seal, and then wet-dry roof patch on the nails. We live in WA and any fix now will have to be done in the rain. Anyone have any ideas? It's about 15x'75'.
joasis 12-13-2006 07:40 AM
If the metal is in decent condition. what I would do is pull the nails, and replace with "woodgrip" 2-1/2 inch screws, and use butyl tape on the laps, universal closure foem on the ridge, if it has a ridge. All of this can be done progressively, without actually removing the roof panels. You can find the screws and closure from dynamicfastener.com/ , Good luck.
HarryHarley 12-13-2006 03:01 PM
I had the same problem. I have a 30 x 60 barn. The roof was 20 years old. Joasis is exactly right. The condition of the tin is where you start. I spent a few years delaying the inevitable. The nails kept backing out and causing more leaks. When I did take the old roof off I can't tell you how many more nails were loose that I never saw the first time. Some of the dripping inside the barn were 5 to 10 feet feet from where the water was leaking in. Absolutely use stainless steel screws with the rubber washer built into the hexhead.
You won't need any caulking using these special roofing screws.
Good luck and Happy Holidays.
halleloucu 12-31-2006 12:47 PM
washer screws
Be careful not to over tighten the screws!! halleloucu
AaronB 01-31-2007 11:45 AM
Polyurea membrane seamlessly applied over entire roof, installed to specs will last a LONG time leak-free.
joelzy 03-02-2007 07:32 AM
i have a metal roof and it leaks when it rains i have a flat roof. when it snow it leaks to any anwers to my problems thanks.
AaronB 03-03-2007 09:37 AM
Sure, we have answers...just go ahead and ask a question.
debisans 10-22-2012 11:25 PM
Help, New Metal Roof STILL Leaks!!!
This is my first post so please forgive me if I do not do it exactly right or if it is in the wrong location, but here is my question.
We have an add on to our house with a flat roof. A couple of years ago it started to leak, we tried and tried to fix it but it still leaked so we replaced it with another flat roof. It still leaked so we replaced that with a shingle roof and it still leaked. We now have put on a metal roof and it still leaks. We believe it is coming in where the addition meets the original roof. We have done everything we can think of and it has cost us thousands of dollars. PLEASE any advise on what we're looking for and how to stop it.
joecaption 10-22-2012 11:31 PM
#1 Go back and add your own post, not just add onto someone elses.
Post some pictures.
Make sure your location is in your profile.
