Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-08-2006, 08:12 AM   #1
Metal Roof Leaking
I have a barn, it is 36x72 feet. I noticed a leak the other day. The sections of sheet panels are all " 2x16" one piece, 16ft to the peak. I notice some screws backing out here and there. How should I go about trying to stop the leak? should I back out the screws that are loose and replace them with the rubber washer type screws? I dont see any breaks or cracks in the sheets of roofing itself. Thank you...
econdave is offline   Reply With Quote
Old 06-08-2006, 08:28 AM   #2
Metal Roof Leaking
That would be a good place to start.
Any gaps at the peak?
redline is offline   Reply With Quote
Old 06-08-2006, 10:19 AM   #3
renovations
Metal Roof Leaking
Yes, I would replace all the screws with new, neoprene washered ones. With any luck, the original screws were the smaller ones so that if you replace them with the larger then they will both grab the wood and seal the hole.
Bonus is offline   Reply With Quote
Old 06-08-2006, 01:29 PM   #4
Commercial Roofing
AaronB's Avatar
Metal Roof Leaking
Both good advice. If that doesnt get it, try a polyurea spray in place membrane system.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 06-08-2006, 02:50 PM   #5
Metal Roof Leaking
I replaced some screws, most were lose on the ridge. I notice some rust in spots, dont know how old the roof is. Is there any way to slow down or stop the rust before it gets through the tin? some kind of spray maybe? I will have to wait for a good rain to see if leak stops.
Old 06-08-2006, 04:08 PM   #6
Commercial Roofing
AaronB's Avatar
Metal Roof Leaking
Yes. For any roof restoration, you need to clean the rust off. Take as much as you need to until all scale rust is gone, surface rust remains, but 90% discarded, in other words, down to solid metal. Aply a zinc-enriched primer to all affected areas, paint or restore.
Old 06-08-2006, 04:45 PM   #7
Metal Roof Leaking
so in other words, wire brush as best I can and then apply primer? this will take hours as the roof is so big. any easier method? thanks in advance.
Old 06-08-2006, 11:30 PM   #8
Commercial Roofing
AaronB's Avatar
Metal Roof Leaking
Well, it sometimes takes us days to do this.
Old 06-09-2006, 12:27 AM   #9
renovations
Metal Roof Leaking
Pay Aaron to do it, that won't take you any time at all. :D
leaking tar and gravel roof meleis Roofing 9 01-05-2008 11:27 PM
Leaking roof -recommend a roof coating? Faust Roofing 5 07-12-2007 11:09 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Help- leaking flat roof, alum?metal? xoroniox Roofing 1 04-24-2006 12:03 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
