Metal Roof Leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-25-2006, 04:04 PM   #1
Rewards Points: 150
metal roof leak
I have a leak on my barn roof. Under the ridge it looks like they used some kind of blue foam to keep rain from getting under the ridge top. Is this available at Hardware stores? thanks
econdave is offline   Reply With Quote
Old 07-25-2006, 04:18 PM   #2
Without seeing it would be hard to tell what it is.
They may have just used expanding spray foam???
The expanding spray foam in a can is purchased at many hardware stores.
redline is offline   Reply With Quote
Old 07-25-2006, 07:39 PM   #3
Rewards Points: 150
no, it isnt the expandable foam, its soft, almost like a sponge. I was thinking about using the spray foam that doesnt expand, I believe it is for doors and windows. Any other suggestions would be greatly appreciated.
Old 07-25-2006, 08:50 PM   #4
Commercial Roofing
AaronB's Avatar
non blown foam? Sounds like youre looking for a sprayable membrane? Look into polyurea for long term high performance waterproofing.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 07-26-2006, 12:37 AM   #5
renovations
My roofing supplier has foam strips to match the profile of the roof that just tuck under the ridge.. They're sticky as well. Get the profile and go buy them, up here, they're ~$1.00/ft
Bonus is offline   Reply With Quote
Old 07-26-2006, 06:36 AM   #6
Rewards Points: 150
what do you mean by get the profile? sounds like the stuff they used, it just tucks under the ridge vent.
Old 07-26-2006, 12:02 PM   #7
renovations
Yeah, it does, but there are a lot of different shapes of steel roofing, and they make the gaskets to fit the different shapes (profiles).
Old 07-26-2006, 04:19 PM   #8
Rewards Points: 150
I will look for it, thanks
Old 07-26-2006, 06:24 PM   #9
General Contractor
joasis's Avatar
You should be able to find an expandable foam closure in 20 foot rolls. Has a sticky side, and after a few hours, will expand..another name for it is universal expanding closure...if you can't find it, let me know and I will give you a number to call where you can get it. Since it is universal, you won't need to worry about the profile of the roof panels.
joasis is offline   Reply With Quote
Old 07-26-2006, 10:24 PM   #10
Commercial Roofing
AaronB's Avatar
Now that sounds handy.
Old 07-27-2006, 01:28 AM   #11
renovations
"Now that sounds handy."
No sh!t, got a manufacturers name? Website?
Old 07-27-2006, 08:17 AM   #12
General Contractor
joasis's Avatar
I buy it direct from our steel supplier...800 256 3237, Longreach Steel, ask and I am sure they would be happy to sell you a case, or tell you the direct supplier. If the tole free doesn't work for you, call information and get the direct number..they are out of Tecumseh, Oklahoma.
I didn't see any in the Dynamic Fastener catalog, but they should also have a source for it. www.dynamicfastener.com/
Old 07-27-2006, 12:31 PM   #13
renovations
tks, joasis
Old 08-03-2006, 06:18 AM   #14
Rewards Points: 150
would it be alright to use a can of exapandable foam like they use for insluating? it is just on small section that is missing this ridge vent membrane. Thanks
garage roof leak Chicago Bill Roofing/Siding 8 05-05-2009 02:07 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
1928 metal roof rusting basilbiko Roofing/Siding 5 07-19-2006 12:57 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
