Metal Roof Install - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-08-2012, 07:55 PM   #1
Solutions (handyman)
Rewards Points: 364
Metal roof install
We are adding a metal roof to an existing roofed residence. A couple of questions for the pros. If the roof appears to be in over-all good shape, should the shingles be removed prior to adding a metal roof? Either way, shingles removed or not, does the roof also require strapping? If so, is this for air movement or another reason? Any additional advice is appreciated.
Mark
Mark Harvey is offline   Reply With Quote
Old 03-08-2012, 08:00 PM   #2
Rewards Points: 528
If it is a residence, strip it. if it is a barn, go right over it.
it is not necessary to strap the roof, but a good 30lb felt or equivalent should be under the metal.
framer52 is offline   Reply With Quote
Old 03-08-2012, 08:59 PM   #3
Rewards Points: 2,210
Either take off the shingles or strap over them, do not put metal on right over the shingles.
I used to sell the stuff from 3 different suppliers and they all said this.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
seeyou (03-09-2012)
Old 03-08-2012, 10:02 PM   #4
Rewards Points: 626
strap them and cover it save you time as long as your roof has only one layer of shingles. Use 30 lb felt min
Nailbags is offline   Reply With Quote
Old 03-08-2012, 10:37 PM   #5
Missouri Bound's Avatar
Shingles hold moisture for a long time. If you cover shingles and not provide a way to ventilate the metal roof it will fail prematurely. If you possible can, remove the shingles. The strapping is the second choice.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
seeyou (03-09-2012)
Old 03-08-2012, 10:49 PM   #6
removing shingles also lessens the weight. gives a smoother surface
seeyou (03-09-2012)
Old 03-10-2012, 10:55 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,984
strip the roof.
Old 03-13-2012, 11:40 PM   #8
While you don't have to pre-drill holes for your screws, pre-drilling panels will make it easier to get the screw lines straighter. - You can predrill a stack of about 10 panels at a time. - Make sure you measure for pre-drilling accurately.
mathewross is offline   Reply With Quote
Multi rib metal roof on double wide...static vents wpilotm Roofing/Siding 0 09-10-2011 03:51 PM
Voltage in Metal Roof and Gutters TITAN2390 Electrical 4 10-07-2010 07:44 PM
mobile home related metal roof insulation chris313scorpio Building & Construction 0 09-28-2010 09:29 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 10:00 PM
