Metal Roof Improperly Installed - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-15-2012, 03:54 PM   #1
Metal Roof improperly installed
I bought a house a few years ago with a corrugated metal roof.
http://tinyurl.com/369larsen
In a recent windstorm some of the panels have blown off. This has led to a discovery that the panels were not attached to any strapping, they were just drilled directly into two layers of shingles.
Since there is no venting in the roof and the whole roof is improperly installed, should I just tear it off and shingle up or take off the roof, replace the damaged components install strapping and re-install?
toohfo is offline   Reply With Quote
Old 05-15-2012, 09:25 PM   #2
Doing This Way Too Long
Rewards Points: 532
Obviously the sellers put the cheapest and quickest lipstick and rouge on in order to sell the place. Whatever you decide to go back with it will need to be stripped down to the deck and done properly. You cannot "repair" it the way it is.
Personally, I don't think corrugated roofing belongs on anything short of a chicken coop or storage shed.
OldNBroken is offline   Reply With Quote
The Following 2 Users Say Thank You to OldNBroken For This Useful Post:
gregzoll (05-19-2012), Windows on Wash (05-16-2012)
Old 05-17-2012, 04:24 AM   #3
This type of roofing is not required by code nor by manufacturer instructions to be installed on battens. While ventilation is important to most types of home construction, it is often done in the attic. Realistically, with horizontal battens (and no vertical battens) behind a steel roofing system, you really do not get the benefit of passive ventilation anyway as the battens block the bottom to top airflow. Do you know who manufactured the roof? My suggestion would be to contact them and get their help in evaluating your situation and determining a remedy.
Todd Miller is offline   Reply With Quote
Old 05-17-2012, 10:51 AM   #4
Rewards Points: 532
More than likely the local big-box store. It's not a roofing system, it's simply a material that can be fashioned into a "roof".
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 02:41 PM
metal roof flash problem? beresford Roofing/Siding 15 01-11-2012 10:30 AM
Rear porch metal roof LeeN Roofing/Siding 0 08-20-2011 09:06 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
