Metal Roof To Gutter Transition. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-10-2013, 04:02 PM   #1
Rewards Points: 256
Metal roof to gutter transition.
I am familiar with roofing with asphalt shingles, and have put corrugated metal on sheds, but never on a house with gutters.
What is the best DIY way to flash or otherwise deal with the transition between metal roofing and the gutters?
Mike
michaelcherr is offline   Reply With Quote
Old 04-10-2013, 04:38 PM   #2
Rewards Points: 13,270
Got a picture?
There should have been an overhang, no flashing needed.
Old 04-10-2013, 07:14 PM   #3
Roofmaster
Rewards Points: 2,172
Are you attempting to put a through fastened corrugated roof on a residence???
Old 04-10-2013, 07:45 PM   #4
funfool's Avatar
Rewards Points: 534
I always flash the edges with same colored drip edge as the metal roof.
I also set a string from one side of roof to the other to represent the over hang for the metal roof. Then set the sheets to the string. Is really easy to set first panel with 1" overhang, next sheet if not exactly where it should be, will be even with first sheet at 1" and 1 1/8" on the other side. It is worth the few extra min to setup the string for a guide, and will save time in the long run.
The gutters are attached just like any other roofing. To the facia.
funfool is offline   Reply With Quote
Old 04-11-2013, 09:36 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,820
Pictures will get you much more specific and concise answers.
Old 04-11-2013, 09:57 AM   #6
Rewards Points: 256
Yes pictures help especially for questions about a specific situation or repair. This is a general theoretical question. No picture is possible or helpful, since I currently have asphalt shingles.
Most of the drip edges I've seen lay flat. Curious if I needed to do anything special because of the raised ribs on roof panels.
Edit: I should have done more research before asking a question. I downloaded a PDF installation Guide of a product I'm considering. That answered my questions. Thanks for the help.
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 06:39 PM
Finished Attic with Metal Roof jonathan03 Remodeling 3 05-13-2010 06:50 AM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 06:51 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
