Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-13-2010, 08:05 PM   #1
Metal Roof guage
I've been flipping through previous posts; I see recommendations to use 26g. I just got a quote to use Fabral Grandrib 3, which is only 29g. Seems thin, but I'm not a roofer. We don't have hail here, or rather very infrequently. Is 29g ok, or is that too thin to bother? I'd like metal, but I hate doing things twice.
supton is offline   Reply With Quote
Old 04-13-2010, 08:14 PM   #2
Commercial Roofing
AaronB's Avatar
Metal Roof guage
I would have no issue with that as long as it is over a solid substrate.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-13-2010, 08:44 PM   #3
Metal Roof guage
What would count as solid substrate? I think I have 1x6's for roof planking. The guy wants to only pull off the first few feet of shingles, to make sure the edges are fine (I have had ice damming issues), but put down a "titanium" underlayment over the rest of the shingles. My neighbor thinks I should strip the roof instead, which I kinda lean towards.
Oh, and thanks for the quick response.
Old 04-13-2010, 09:04 PM   #4
Commercial Roofing
AaronB's Avatar
Metal Roof guage
It's always better to tear off before you replace.
1x6 is fine as long as its not spaced more than 1/4 apart. Sometimes we run into skip sheathing, in which the deck planks are spaced a few inches apart in order to accommodate a solid roof covering.
Old 04-13-2010, 09:34 PM   #5
Electrician 30 yrs +
Metal Roof guage
I have 29 ga on my house. been there for 10 years , still looks as good as it did when installed.
i have installed many roofs with 29 ga never had an issue.
huck is offline   Reply With Quote
Old 04-13-2010, 09:58 PM   #6
Metal Roof guage
From what I can see, it is quarter-inch or less, on at least one roof which I can see under. But I haven't looked at the edges, to see what is there.
Ok, I hear you on the stripping, it seems wise to me too. The contractor seemed to think stripping was expensive (what isn't?) and not necessary, but no matter what route I go, it seems like stripping is a good idea (if I shingle, put down snow and ice shield).
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing 7 06-04-2009 03:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
New Metal Roof agrace Roofing 2 08-24-2008 11:27 PM
