Metal Roof - Curved Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-16-2010, 12:29 PM   #1
metal roof - curved roof
Our house is an older home with a 7/12 pitch at the peak but it flattens to about a 4/12 at the eaves. Would like to put on a metal roof of some kind but would like some suggestions on the way to go.
olderndirt is offline   Reply With Quote
Old 06-16-2010, 02:11 PM   #2
jlhaslip's Avatar
Rewards Points: 2,140
pictures would help.
Metal roofs can be 'shaped' to fit, but I am not the guy to answer with specifics on how to do it or what the range of movement allows.
It likely depends on the profile and guage of steel.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 06-16-2010, 06:42 PM   #3
If on piece bending to the pitch break, then a very skilled tinner/sheet metal contractor would be needed. If a 2 piece panel is used, then an "Apron Flashing" also called a pitch break flashing would need to counter-flash the lower panel and slide under the upper panel.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-18-2010, 06:49 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
As mentioned above, an experienced tinner could run a true standing seam roof right through that pitch change. But, most pre-manufactured roofing systems (snap lock or exposed fastener) won't bend. The roof would have to be treated as two different sections with the 4/12 roof stopping at the transition point and an apron laid over the top of it (as mentioned above). The 7/12 roof would then start above the apron. Cosmetically, the apron creates a horizontal strip (probably 7" or so wide) at the pitch change. If not detailed properly, this is often the source of leaks. Not saying it can't be done properly, but I get called to repair snow related problems transition flashing areas fairly often.
seeyou is offline   Reply With Quote
What kind of paint to use on a continuous metal roof? TitaniumVT Painting 6 12-23-2009 08:33 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 03:58 PM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 05:51 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 02:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
