Originally Posted by ionized
I am probably going to have a standing-seam metal roof installed on my house and garage. It will probably be cool roof. I am pretty naive about everything except the difference between standing-seam on the one hand and “r-panels on the other.
Where is the home located? If you are in a mixed climate, the reality is that roof color (in metal) will not make that much of a difference in savings.
Metal has a much higher emissivity compared to asphalt so you are going to be much better off in either scenario regardless of color.
Standing seam is the preferable of the two materials with a more bullet proof installation (i.e. hidden fastener) and classic look.
The re-roof will include two types of construction. One is replacement of an existing shingle roof. The existing roof deck is planks, not plywood. I plan to spray-foam insulate the underside of the deck and seal the attic.
What is the rationale behind the sealing the attic? Spray foaming roof decks are great and work very well with metal (make sure you put down a good underlayment and do not spray the back of the metal) but that is an expensive option unless you are converting that to conditioned space and using it as living space.
If the goal is purely efficiency, you can do a whole lot more on a whole lot less budge with proper air sealing and insulation.
The other two roofs are flat-roofed additions. There, I plan to frame with minimal rise for the metal roofing. These areas will be sloped in different directions (right angles). One is a lower-slope continuation from one of the gabled roofs. The other will border on that and end at the gable end. The existing roofing has to be removed to eliminate the vapor barrier and that will also be spray-foam insulated before the metal panels go on.
How flat is flat? Mechanically locked standing seam can be run on a 0:12 application and are used in flat roofs that have proper drainage allocations.
Spray foaming flat roofs are a good ideal because they are tough to get good insulation value in via traditional methods. I would recommend thermally breaking the joists via rigid foam in most cases as well.
I will appreciate any advice that is offered. I have some specific questions. Are there different options for treating the edges of the roof? What are the choices for underlayment? This roof will be difficult to get onto safely compared to shingles and the flat roof. Is there any practical way to install attachment points for a safety harness? (I am planning on installing both photovoltaic and solar thermal. I have nearly South-facing gable on both the house and garage.)
Do you mean the edge of the roof or the edge of the panel (i.e. edge priming/painting)?
If you are coastal, go with aluminum and most steel panel makers will not warranty them against salt spray or at minimum they will have reduced warranties.
Go with synthetic underlayment and don't worry about the breathable (i.e. Deck armor) stuff. A good woven poly is fine.
Yes, if you are going to routinely be accessing the roof, hide some attachment points under the ridge cap detail.
I understand that the metal is lighter than the shingles that will be removed. The dead load will be less. Do I have to be concerned about the corresponding increase in the live load? This is Gulf of Mexico hurricane zone (New Orleans). I wonder if hurricane ties should be added at this point if it is practical.
Thanks for reading!
Metal is considerably lighter than asphalt but I don't think you need to worry about live load reductions. I have never seen a roof held down by the shingles.
The structure of the metal and its increased wind resistance will easily outweigh the benefit of the additional weight of the asphalt. The metal roof should also be screwed down for security and increased strength.
I would absolutely add in the hurricane ties now. You are making for a lifetime (barring mechanical damage) roof and they are cheap. Do it right...and do it once.
