Metal Roof Condensation In Garage - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-13-2013, 12:08 PM   #1
randlefactor's Avatar
Rewards Points: 39
I noticed drip patterns on my garage floor and looked up to see what I think is condensation. The last 2 days we've had really high temps compared to normal in Syracuse NY so the snow has been melting like crazy. The water is running along down and maybe collecting in the soffit. I see drips on the soffit vents.
It appears I have plenty of soffit vents but no ridge or gable vent. Is this the likely cause of the condensation and what would you suggest installing? Notice the foam that someone sprayed along the ridge.
Thanks!
Also I should note I found out this garage was built by a DIY owner in 2000. ... So don't hold back if you see anything strange or wrong with the structure.
Metal Roof Condensation in Garage-image-528140007.jpg   Metal Roof Condensation in Garage-image-2928770396.jpg   Metal Roof Condensation in Garage-image-2199978202.jpg   Metal Roof Condensation in Garage-image-2794428.jpg   Metal Roof Condensation in Garage-image-2125868547.jpg
Metal Roof Condensation in Garage-image-4279956920.jpg   Metal Roof Condensation in Garage-image-289761839.jpg
randlefactor is offline   Reply With Quote
Old 01-13-2013, 12:41 PM   #2
Rewards Points: 690
Your warm wet car is raising the dew point temperature until the roof temperature can't take it any more and drips plus channels water to the soffits. A couple of reasonable choices are to heat the garage to lower the dew point or perfect insulating job. A not so reasonable suggestion is to leave the car outdoors until it cools and dries.
SeniorSitizen is offline   Reply With Quote
Old 01-13-2013, 02:54 PM   #3
Rewards Points: 13,260
No ridge vent and not enough soffit vents.
No air sealing, insulation and sheetrock on the ceiling.
Old 01-14-2013, 12:09 PM   #4
Roofmaster
Rewards Points: 2,172
Does it drip if you leave the garage door open? or just after you close it?
Old 01-14-2013, 11:14 PM   #5
Rewards Points: 39
I think what happens is the warm moist air freezes on the underside of the cold metal roof each time I pull my car into the garage. Then during the warm weather, all of that collected moisture melted and dripped all at once causing a big mess.
I think I'll add either a ridge vent or gable vents and see if that helps. Does anyone know if wasps can fly through the holes in a ridge vent?
Old 01-14-2013, 11:29 PM   #6
One way around that is to buy some Cobra vent and cut it to width so it fits inside the metal vent.
http://www.gaf.com/Roofing/Residenti..._Exhaust_Vent/
Old 01-15-2013, 10:36 AM   #7
Roofmaster
That's why I asked if it drips when you have the Garage door open.
You have a thermal bridge. Heated air containing moisture is hitting the underside of the deck, condensing and dripping.
I have to disagree with Joe on the Cobra, as I consider it to be trash, but I agree with the concept. A good ridge vent can be fabricated for a metal roof that provides excellent ventilation, as long as your soffits are fully vented.
Another option is a powered ventilator that works on a timer when you open or close the garage door? Pretty simple circuitry for a IC nut.
A third option is to have your metal roof sprayed with PUF and coated with Silicone. That will stop it cold, as the insulation will be on the outside, and the dew point will fall in the insulation.
A fourth option is to take that silly metal roof off, add trusses, sheathe it and put a shingle roof on it. The plywood and shingles are an insulator, as opposed to metal, which is a conductor. Through fastened metal roofs leak after a few years anyway, as the fasteners egg hole due to movement.
This is silly construction for a cold region, IMHO
The Following User Says Thank You to jagans For This Useful Post:
randlefactor (01-15-2013)
Old 01-15-2013, 11:24 PM   #8
Registered User
Rewards Points: 5,212
http://www.designandbuildwithmetal.c...h_7_13_09.aspx
http://www.mbma.com/pdf/2009Condensa...eet_112509.pdf
"So don't hold back if you see anything strange or wrong with the structure."--------- the front side walls of the garage appear to have hold-downs for shear resistance because the concrete looks like spalling below the siding--- good. Bad; the windows in the shear panels defeat the purpose. You also appear to be missing these, per minimum code for uplift; http://www.strongtie.com/products/connectors/H.asp
http://publicecodes.cyberregs.com/ic...9_8_par040.htm
For your high wind area: http://publicecodes.cyberregs.com/ic...001_par004.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 01-15-2013, 11:30 PM   #9
A ridge like this will work and keep the bugs out.
Old 01-16-2013, 08:53 AM   #10
Roofmaster
Joe, a ridge like what?
Reparing Large Hole In Standing Seam Metal Roof xquercus Roofing/Siding 7 08-18-2012 10:07 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Replacing shingled roof with metal roof myminpins Roofing/Siding 3 06-26-2011 10:43 AM
Finished Attic with Metal Roof jonathan03 Remodeling 3 05-13-2010 06:50 AM
metal roof condensation jowens80 Roofing/Siding 2 02-17-2009 10:23 PM
