Metal Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-15-2010, 05:52 PM   #1
metal roof
Just had a metal roof installed on 2x2 strapping. I want to know if the ridge vent is supposed to have the plywood cut out on both sides of the ridge board. The existing vents were just taken out to allow air flow to go up between the metal tiles and existing ashphalt roof.
Thanks.
Mark
mark7 is offline   Reply With Quote
Old 08-16-2010, 10:14 PM   #2
Remodeling Contractor
Yes, a strip of roof sheathing should have been cut out along the ridge. Just removing the old vents and going over them won't cut it. Now air will not have a direct route outside and will essentially have to travel around a corner to escape. And if the strapping was installed horizontally, it will more than likely cut off all air flow alltogether. Sounds like the roofers got a little lazy on you.
eisert is offline   Reply With Quote
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
New Metal Roof agrace Roofing/Siding 2 08-24-2008 11:27 PM
