Metal Roof??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-02-2008, 10:42 PM   #46
the roofing god's Avatar
Send a message via MSN to the roofing god
I would recommend new plywood!!!,when they cover that deck,and then gun nail the roof,you won`t know they missed till the nails are popping up thru the new roof-don`t be silly
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 03-02-2008, 10:44 PM   #47
as I wrote previously:
not to correct anyone but the plywood doesn`t show in the pics,what you see is probably 1x8-10 decking with 1x2s filling the spaces,he definitely should have the entire roof resheathed over the 1xs,I also see poor spacing on the beams,and areas where the beams appear to be missing and broken,so you should be looking at that also in addition to the mold growth visible in some pics---
Old 03-04-2008, 09:20 AM   #48
sounds like...
Yeah sounds like no plywood. And just go with having the whole roof resheathed.
Tdoggy187 is offline   Reply With Quote
Old 03-04-2008, 10:14 AM   #49
resheathing is installing plywood over the entire existing roof
Old 03-04-2008, 11:47 AM   #50
Thumbs up
it is...
Can you tell I know nothing about roofing, lol
ok so all new plywood it is!!!! Which is also known as "resheathing"
roofing God your in Rockland County. I wish you were in "Steuben County" :-(
Old 03-04-2008, 12:58 PM   #51
thanks for the compliment--be sure not to remove the old sheathing,as that is a lot of your structural support with this old house,better to strengthen it by sheathingt over,then do any necessary repairs to framing from below-best of luck-use a good contractor,it sucks to use someone cheap,then have to redo it long before you should have to
Old 03-04-2008, 03:35 PM   #52
Wink
i hope to
Yeah I hope to use a good one. when exactly I'm not sure of. Hopefully soon though. Got to think some rain will be coming with Spring right around the corner.
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
1928 metal roof rusting basilbiko Roofing/Siding 5 07-19-2006 11:57 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
