Metal Roof??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-22-2008, 09:55 AM   #16
Talking
hoping to
Hoping to do a complete tear off. Then put down all new plywood and put down shingles or possibly a metal roof. Planning to get it done this coming spring. I can't see getting it done in the winter. Sounds like Spring would be better. Thanks for all the Help
Tdoggy187 is offline   Reply With Quote
Old 02-22-2008, 10:24 AM   #17
Make sure that the contractors all have the opportunity to get inside of your attic to inspect the rafters.
It looks like, from your 3rd and 4th photos, that there may be too much rot occurring on those rafters to be comfortable with and there are probably more that you did not take photos of too.
They probably can "sister" in new rafters right next to them, unless they are falling apart.
Ventilation will be key, though. Also, you probably do not have to replace all of the plywood decking on top of the skip sheathing, but just to cover you butt, get an option for pricing that out with your contractor. Most of the surface applied decking is probably still in good shape, just not where thew leak stains are located.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-22-2008, 07:20 PM   #18
Question
I got a quote for between 4-5K. He wants to do a tear off and then put up plywood and Architectural shingles. And he was talking about putting up ridge vents. Does this sound about right? Don't think he said anything about adding rafters though...
He said I could do a metal roof if wanted also. Its up to me. Metal would be a little more.
He is pretty well known in the area and has done several roofs.
Old 02-22-2008, 08:29 PM   #19
There are so many factors that go into a proper roofing project.
Firstly, disregarding anyones price, which contractor that you interviewed had the most knowledge and the most detailed specifications?
If it is not written down in the proposal, it is not part of the contract.
If the contractor who gave you the most confidence winds up being the higher priced contractor, please take the time to set up an additional appointment with him, and show the other proposal. Ask where he sees any vast disparities in the specifications.
If those differences are significant enough to you and you can see the benefit of the additional value of a properly trained and quality oriented work force and also if the specifications for the protection of your home, which is probably your most valuable asset, are the most proficient and precisely detailed, you may want to consider using that contractor instead.
Your roof is steep. It is dangerous to work on. Don't let anybody fool you about how they never have any accidents. They can happen.
Does the contractor use empoloyees or farm the job out to subcontractors? Is so, is the subcontractor licensed? Is he insured? Does he pay his employees with actual wages or does he hide the fact from the government and misclassify them as individual subcontractors?
How can you find that information out? Ask for the crew foremans name and one other roofer that will be on the crew working on your home. Then ask for the most current check stub which shows the taxes deducted. If they fail to provide you with this validation, they have something to hide. Period! Don't trust them from that point on.
Here, I just recently posted this in another topic thread, but it will be a valuable guide for you on how to choose a good contractor and what questions to ask them.
Follow the guidelines and most importantly, check on the items I just spoke of and also previous references.
Also, ask for a home owner who they had a problem job with and how they straightened it out to everyones mutual satisfaction. If they have been in business for any reasonable length of time, they will have had some obstacles in their desire to achieve customer satisfaction.
It is not as important that they had any problems, but more so, how did they react to resolve them. That will show their true character.
Ed
Roofing is Not Brain Surgery. There are many Wrong ways to roof a house. But…There is only…One “Right Way”, By Following All of the Manufacturers Specifications. Over 90 % of All Roofs Done - DO NOT Qualify for the Manufacturers Long Term Warranty!!! ( According to studies by GAF Roofing Corp., Air Vent Inc., & Alcoa )
10 Very Important Tips You Should Always Follow
“What You Should Know Before Hiring Any Contractor!!!”
1) RELIABILITY: Verify that the contractor you call has been in business in your area for At Least 10 Years. Over 85 % of all roofing contractors are out of business in less than 5 years, way before the warranty expires and before many roofing problems begin to show up and cause problems. 85 % of those remaining do not last till the 10th year. (Department of Labor Statistics)
2) INTERVIEW: Make time to meet with any contractor you call, in person, at your home to review the proposal and detailed specifications. Try to select a Knowledgeable, Organized, Experienced, and Locally Established contractor who will take a personal interest in your roofing project. Choose one who has an established track record of many similar roofing projects done in your local area. If they will farm out your roofing job to an unknown subcontractor, you should interview them as well.
3) REFERENCES: Insist on a minimum of at least 20 - 50 recent job references & also several from each year they say they were in business. Ask for customer testimonials. Drive past several of the jobs to check for proper venting, flashing details, and general appearance. Ask previous customers if they were satisfied and if they would use them again. Contact your local building inspector for verification.
4) BUYER BEWARE: Be suspicious if any contractor requires you to get the roofing permit. The party who applies for the permit is responsible for building code compliance. What happens when the roofing specs do not conform to the local codes? Why won’t they be responsible for it? Also, Do Not Ever pay more than 50 % when paying a deposit.
5) ADDRESS AND PHONE NUMBER:Make sure that the contractor actually has a physical location that you can find if you need to locate them in the future, not just a mailbox etc., drop box. Do they have an actual office and material storage shop or just work out of the back of their pick up truck. Make sure they have an actual local telephone # and not just a cell phone. When problems occur, it is much easier to find someone if you already know how to, in advance. Check out his drivers license address.
6) LICENSE, INSURANCE AND BONDS: Insist on receiving a copy of the Contractors State of Illinois Roofing License, General Liability Insurance, Workers Compensation Insurance and their Roofing Bond. Don’t just assume they have it because they tell you so. They should have enough pride in themselves to include a copy for each customer.
7) PROPOSAL AND/OR CONTRACT:Insist on a very thorough and detailed written proposal and examine it for complete descriptions of the work and specifications, including approximate length of the job and payment procedures. Verbal agreements should be added to the written agreement. You MUST, by law, be advised in writing of your 3-Day “Right To Rescind” if you change your mind and receive all of your deposit money refunded to you.
8) EMPLOYEES OR SUB-CONTRACTORS: If your contractor farms out the job to a sub-contracting crew, they too must supply you with their Roofing License, General Liability and Workers Compensation Insurance and Roofing Bond. If they don’t and someone gets hurt, you may be liable. The sub-contractor should be interviewed as well. Dedicated trained experienced Employees are more desirable due to continuing training and experience.
9) CONTRACTOR TRADE ASSOCIATIONS: Quality control begins with dedication, the amount of proper knowledge and previous training from past projects and from advanced learning through many contractor trade associations. Memberships in any related trade association and certificates of completion from manufacturers product training classes authenticate the more dedicated professional.
10) USE YOUR NOGGIN: 85 % of all construction lawsuits involve roofing related problems. You only have one chance to make the “Right 1st Choice”. If one contractor tells you something extremely different than another contractor, then either do your own research or have the contractor provide documentation to justify and support his analysis, especially about Intake & Exhaust Ventilation, Plywood vs. OSB Particle Board, Ice & Water Shield & Flashings.
You need to be concerned with the initial price only once… But you are going
to be concerned about Quality…for many years to come!!!
The following named Roofing Contractor is an esteemed selected board member of the Professional Roofers Advisory Council, (PRAC). If You Want Solutions, Not Problems, Call…
Old 02-22-2008, 08:59 PM   #20
Wink
Thank You Ed
Ed thanks for all these tips. Yeah I want to get it done right. I want it to last a long, long time. And doing it right will be the way for that to happen...
I have had several different estimates already. From 5K-13,5000. I will continue to have.... Thanks again...
Old 02-22-2008, 09:13 PM   #21
the roofing god's Avatar
Send a message via MSN to the roofing god
not to correct anyone but the plywood doesn`t show in the pics,what you see is probably 1x8-10 decking with 1x2s filling the spaces,he definitely should have the entire roof resheathed over the 1xs,I also see poor spacing on the beams,and areas where the beams appear to be missing and broken,so you should be looking at that also in addition to the mold growth visible in some pics---I`m a rockland county roofer--where exactly are you in upstate new york ???
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 02-22-2008, 09:20 PM   #22
I couldn't really tell from the photos I mentioned, if that was plywood decking already over laid on top of the skip sheathing, or if it was already filled in with firring strips.
We need people like you, with better eyesight on here more often to correct my vision.
Ed
Old 02-22-2008, 09:31 PM   #23
no,I just have seen the hacks pull these maneuvers before,thought it didn`t look right,and when I looked close,I realized what it was,when they put that 1x2 filler in,god help you if you hit it with a nail ,it will break,this house could be very close to me,looks like spring valley or hillburn,but the older towns have a lot of these older homes,when I worked for someone else,I would always find my name on contracts to these style houses(dogs/pigs),and the boss would smile and say ,It`s because you do them so well-lol
Old 02-22-2008, 09:56 PM   #24
Wink
I am in.....
Ever here of Hornell NY? I'm very close to that. Feel like coming down for some work? :-)
Old 02-22-2008, 10:02 PM   #25
what county is that in?
Old 02-22-2008, 10:12 PM   #26
Steuben county
ITs in Steuben County... Know any good roofers from Steuben???
Old 02-22-2008, 10:18 PM   #27
have to figure out where steuben is (lol),is that by utica,syracuse,newark (ny),canada ,give me some landmarks
Old 02-22-2008, 10:21 PM   #28
lets see
About an hour and a half South of Rochester... Maybe three or 4 hours South of Canada... Have you ever heard of Livingston County? Monroe County?
I think I am like 4 and a half hours away from you in Rockland County...
Old 02-22-2008, 10:32 PM   #29
at least 3 or more looking at the map,closest I know a roofer is newark,and that`s far for him--you have an old home,the details are what`s gonna make or break the roof,I think a proper bid would be closer to 10-12,000.00$ to get it done right and not leave things out ,be very thorough as you don`t want to be doing it again in 5 yrs,the homeowners who think their roofs look pretty usually have no clue as to what`s proper,be sure any rafters are repaired,any plywood installed is cut at and secured to rafters(more plywood waste)with odd size rafters do not let him end plywood off the rafters and "rabbit"nail it to the pine boards ,it will come up thru the roof if you do--post your proposals here so ed,I,or other pros can evaluate them for you-good luck-the guy in newark is marshall exteriors
Old 02-22-2008, 10:42 PM   #30
Here is some information on the company TRG referred.
Adam Olschewske
newark, NY 14513
Username: marshall exteriors
Website: http://www.marshallexteriorsny.com
Ed
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 05:39 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
1928 metal roof rusting basilbiko Roofing/Siding 5 07-19-2006 11:57 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
