Metal Roof??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-21-2008, 11:15 AM   #1
Question
Metal roof???
I got a shingled roof. Looks like 4 layers. They are old and worn. I got someone who says we can put a metal roof right over them. Is this a good idea? Or should we have to do a complete tear of, put down some plywood, and then the metal roof? I'm not sure how metal roofs work exactly? Any help would be great. Thanks...
Tdoggy187 is offline   Reply With Quote
Old 02-21-2008, 11:31 AM   #2
I'm curious about metal roofs too. I can't imagine anyone would tell you that it's OK to put a metal roof over 4 layers of shingles though. Maybe someone will chime in with some good links for metal roofs.
perpetual98 is offline   Reply With Quote
Old 02-21-2008, 11:48 AM   #3
I put a new metal roof on over the shingles, and put foam insulation on too. I see a big difference in the summer with AC not coming as much. The retailer I got it from leave the shingles on. He also said the lighter the color the more heat reflection you will get.
ajh359 is offline   Reply With Quote
Old 02-21-2008, 12:01 PM   #4
That just seems insane to me, and probably against the code too.
The integrity of a metal roofing system depends on the flashing details and the fastening of the system. Going through that many layers of old, brittle and decrepit aged roofing shingles would seem that the fasteners would be too prone to back out due to expansion and contraction and also by the toggling effect.
That would not be adviseable and would probably cost you much more money to fix correctly in the long, or even short run.
Ed
Ed the Roofer is offline   Reply With Quote
Old 02-21-2008, 12:43 PM   #5
I only had one layer of shingles.
Old 02-21-2008, 01:35 PM   #6
I was referring to the poster who already has 4 layers on now, which already is in violation of any codes I know of.
Ed
Old 02-21-2008, 06:37 PM   #7
Thumbs down
Its a house...
Its a house in upstate NY in a small little town. I don't think its breaking any codes. I'm not positive though. We bought the house and it was like this. This roof must be at least 40 years old...
Guess I shouldn't put Metal up over 4 layers of shingles???
Old 02-21-2008, 08:22 PM   #8
It most definitely is against the national codes, which all towns reference, even if they do not enforce them.
You may be mistaken if you counted the layers yourself, because each layer of shingles look like 2 layers to the untrained eye.
Ed
Old 02-21-2008, 08:32 PM   #9
Thumbs down
ok so if it has 2...
Yeah i could be wrong. Maybe it only has 2 layers of shingles. Then can I just put a metal roof over it? Does this make a difference? Again it is a very old roof. And their have been leaks and water damage to ceilings inside...
Old 02-21-2008, 09:50 PM   #10
electrical contractor
Rewards Points: 150
Around here people will strip the roof with 1x4 lumber then install the metal on that, seems to work, but I wouldent care for the extra weight. I put a metal roof on my house when I built it, no plywood decking just 2x6 strips across the trusses and metal screwed down to the strips kinda like a barn roof. Oh, lest I forget to mention if you use this method count on r-40 attic insulation to hold out the cold.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 02-21-2008, 10:15 PM   #11
Lightbulb
here are some pictures please help guys
Pictures of the inside roof structure. Any advice would be welcome! Thank You all
Metal roof???-roof-structure-inside.jpg   Metal roof???-roof-structure-inside2.jpg   Metal roof???-roof-structure-inside3.jpg   Metal roof???-roof-structure-inside-4.jpg   Metal roof???-roof-structure-inside-5.jpg
Old 02-21-2008, 10:22 PM   #12
a few shots of the outside of the roof
The outside.
And some of the damage it has done inside
Metal roof???-hpim0700.jpg   Metal roof???-hpim0704.jpg   Metal roof???-hpim0705.jpg   Metal roof???-roof-4.jpg   Metal roof???-hpim0715.jpg
Old 02-21-2008, 10:29 PM   #13
Hello,
With the snow load that you may get each year I would advise you to tear it all off and start fresh. I install a lot of metal and the added weight of that plus the snow, plus the old roofing would be too much weight(IMO). Ed makes some very good points about the codes and such also.
Keith
roofboy is offline   Reply With Quote
Old 02-22-2008, 12:46 AM   #14
the roofing god's Avatar
Send a message via MSN to the roofing god
new york should only allow 2 layers,and if it`s upstate we`re talking mega snow,basically you`re better to remove an old roof with moisture problems than to cover it and allow it to get worse underneath,possibly even grow mold,rip it fix damage,then do the metal-the guys are right,especially the guy who mentioned r-40 insulation,and the weight of the snow load as Keith mentioned
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 02-22-2008, 07:47 AM   #15
With the amount of moisture that has already affected the rafters and decking, not to even mention the soaking of the insulation, this should be a "No-Brainer" to decide on removing the existing roof layers, whether 2 layers or 4 layers, just for the fact of repairing the wet and rotted wood and to have access to the attic to efficiently replace the wet insulation.
From your interior attic photos, I would guess that this home once had a cedar shingle roof on it, which lasted at least 50 years on top of skip shething, space board decking. Then, either after an additional layer of composition shingles were added, which would have lasted 20-30 years, the previous owner had the roofs removed down to the skip sheathing. The decking is now solid sheating, with either the gaps being filled in, or the new sheathing being applied over the spaced decking.
I doubt, from your photos, that you have 4 layers on there currently, but you still need to remove the old roofs to do the repair properly and replace the rotted sections. There also may be more evidence of mold growth gowing on, as the section of rafters in one photo clearly showed significant growth already.
When the roof is being done, ensure that you have a properly balanced system of fresh air intake ventilation and roof top, ridge exhaust ventilation.
Ed
not venting a metal roof penny0322 Roofing/Siding 6 03-25-2011 06:39 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
1928 metal roof rusting basilbiko Roofing/Siding 5 07-19-2006 12:57 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
