Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 10-18-2006, 09:24 PM   #1
milkman
Send a message via AIM to g man
Question
metal over wood shakes
I would like to know if i can go right over the top of old wood shakes, it's on an old farm shed .i think it would faster and less mess thanks for any input
g man is offline   Reply With Quote
Old 10-19-2006, 07:28 AM   #2
Commercial Roofing
AaronB's Avatar
You can do anything you want if its your building, but it is not best practice.
It is done a lot over cut shingles, but split shakes are mush thicker ond less uniform, so I do not think I would do it if it were mine.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 10-22-2006, 10:42 AM   #3
no matter what its always a better job to strip the old roof.
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Old 10-22-2006, 06:28 PM   #4
General Contractor
joasis's Avatar
If the shakes are laying flat, and if you use long woodgrip screws, it can be done, but be aware that if you walk on the steel, even 26 ga., you can dent it from the back side and it will be visable from the ground. As the above posts advise, it is always better to strip a roof, but we have installed many over shakes with no problems.
joasis is offline   Reply With Quote
finishing a basement- metal tracks & wood studs sweep the leg johnny Building & Construction 4 03-09-2007 04:05 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
