Metal Over Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-26-2012, 08:10 AM   #1
metal over shingles
I'm in northern New Hampshire and have a second home that needs a new roof. It has one layer on shingles I'm wanting to install a metal roof over it. My plan is to install Grace Tri-Flex over the shingles then the metal roofing. No means of taking shingles off because of disposal. So will this plan be OK?
altannt is offline   Reply With Quote
Old 06-26-2012, 02:09 PM   #2
Carefully read the instructions of your metal roofing.
But.... Probably not allowed.
Evstarr is offline   Reply With Quote
Old 06-26-2012, 02:19 PM   #3
Contacted metal roof co. Tri-flex is fine over one layer of shingles heat rated up to 240 degrees. All set thanks
Old 06-27-2012, 08:26 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Yep.
You need a proper slip layer regardless and if the poly in this case is rated for the heat...you are good.
New Shingles: Defective Shingles or Bad Install? TTZip Roofing/Siding 9 04-30-2013 01:03 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
Help! -- what is causing these shingles to fail? imaginator Roofing/Siding 1 09-18-2010 06:29 PM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Metal Roof Estimate supton Off Topic 5 04-17-2010 03:08 PM
