Metal Over Shingle? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-15-2011, 08:35 AM   #1
metal over shingle?
i have a 14x50 mobile home with shingles and want to go with metal. My question is do i have to put down 1x4 boards or can i screw down on top of the shingles? also im wondering if there is a heat factor difference with boards or not? im planning on ridge venting the full length of the home.
thanks:suzzie
suzzie is offline   Reply With Quote
Old 07-15-2011, 09:05 AM   #2
Rewards Points: 252
The proper way is to remove the shingles, otherwise the metal might not lay flat. If you are going to leave them it would be best to use 1x4 strapping so you have something solid to screw into (especially around vent stacks and other projections).
shazapple is offline   Reply With Quote
metal roof over possibly damaged shingle roof nancy ostin Roofing/Siding 4 03-31-2010 11:32 AM
Metal roof vs asphalt shingle roof Bob_T Roofing/Siding 1 06-20-2009 06:51 PM
metal vs shingle roof shimp Roofing/Siding 3 07-13-2008 01:52 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
