Metal Over Old Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-24-2009, 09:27 PM   #1
Question
metal over old roof?
I have an old roof that had 3 layers of asphalt shingles and a bottem layer of wood shake shingles with 1x4 slats underneth is there any problem with me putting a metal roof directly over the slats or do i have to deck it over with plywood first?
inrightoutright is offline   Reply With Quote
Old 09-24-2009, 09:54 PM   #2
Commercial Roofing
AaronB's Avatar
You should be just fine if the slats are sound, use a proper underlayment, and do the roof 100% properly.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-24-2009, 09:59 PM   #3
I'm assuming you are removing the 3 layers of asphalt & the shakes
or have removed already...."had"
Old 09-25-2009, 09:24 AM   #4
Talking
I appreciate your quick response, and I have torn off the other layers already. The slats are sound. Do you have any advice for which type of underlyment is the best/cheapest?
Old 09-27-2009, 09:40 AM   #5
Check with your metal supplier they seem to know what is best and for what application. I have the same issue and am going to strap the roof with 1x4's just because I don't want to sink a screw into one of the gaps between the old slat boards.
bronco2 is offline   Reply With Quote
Old 10-01-2009, 08:13 AM   #6
Bronco2's issues/questions moved to new thread:
Metal roofing & insulation
metal roof condensation jowens80 Roofing/Siding 2 02-17-2009 09:23 PM
Tired of patching my flat garage roof, I want to reroof it. Metal???? sellingitall Roofing/Siding 2 09-12-2008 08:51 PM
Metal Roof Installation paparon59 Roofing/Siding 2 09-12-2008 08:49 PM
Coastal Metal Roof agrace Roofing/Siding 4 09-12-2008 08:46 PM
metal roof questions tecate1987 Roofing/Siding 2 07-26-2008 03:20 PM
