Metal Chimney Surround Banging Noise - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-27-2010, 12:19 PM   #1
Metal chimney surround banging noise
Even on a mildly windy day, the new metal chimney surround makes a banging sound. The wind pushes the side in-and-out, which causes a sound like a drum. Is there any type of brace or support that the contractor can install to prevent the sides from being indented and springing back into place? Thanks for the help.
etern33 is offline   Reply With Quote
Old 10-28-2010, 03:20 PM   #2
RoofDiagnostics's Avatar
you could add some rivet fasteners to eliminate this issue.
RoofDiagnostics is offline   Reply With Quote
Tags
chimney , chimney surround , wind
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
Leak around chimney - metal roof nelsonC Roofing/Siding 1 09-30-2010 09:56 PM
Steam pipes generating banging noise Dezso3 Plumbing 7 02-20-2010 06:31 PM
To paint or not to paint: the metal chimney cap? ohman Painting 5 08-12-2009 12:00 AM
isolating noise transmission in metal duct work BrandonHook HVAC 2 12-07-2008 07:37 AM
