Metal Carport Roof Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-01-2012, 11:23 PM   #1
Metal carport roof leaking
I want to stop a metal carport roof from leaking. It is one of those with the formed metal frames with the exposed fasteners attaching the metal to the frame. The metal is run lengthwise so therefore the water cannot drain off the sides. The water has to drain off the ends There is very little slope to it so the water ponds on it. There are trees around it so in the past it had pine needles and dirt accumulate on it in places. I am assuming that the main leaks are through the fasteners which have the rubber washers under them.
What are the recommended repair methods? For example would an elastomeric sealant work. Should I caulk over the screw heads with a silicon caulk?
Thanks for any help
Redding is offline   Reply With Quote
Old 10-02-2012, 07:15 AM   #2
Rewards Points: 14,312
A picture sure would be nice.
Is the metal roofing rusted?
Have the old fastners been over tightened and now the washers are cracked or crushed?
Old 10-02-2012, 11:07 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 802
silicon caulk won't last long before it comes off, I would use butyl caulk, it will not harden completely and is sticky as the dickens but it will hold up and last.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-02-2012, 08:18 PM   #4
Pictures of carport roof & screws
Here's a few pictures of the carport roof. The washers under the screws are in bad shape. Would a complete sealing of the roof be a good fix for the leaks in this roof. I think that I would prefer to individually seal each screw head. Metal carport roof leaking-dscn5296.jpg
Old 10-04-2012, 07:21 AM   #5
Simply replacing all those screws with new screws and this time not over torquing them so it crushes the washers will go a long way to keeping it from leaking. Any topacal caulking is going to fail within a year.
Someone messed up 2, things when building that roof. the panels should have been one piece instead of two, and the panels should have been installed with clips and a seam crimper so there was 0 screws exposed.
http://www.bing.com/videos/search?q=...fing&FORM=VDRE
Old 10-04-2012, 09:29 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
A good washing, let it dry, replace the screws/washers, and proper sealing of those lap joints should be fine.
Old 10-04-2012, 03:32 PM   #7
Sealant for sealing lap joints?
What do you recommend for sealing the lap joints? Do you recommend a Butyl sealant? Do they make the screws that I need in a stainless steel?
Thanks for the help.
Old 10-05-2012, 06:57 AM   #8
A good roofing sealant (Vulkem, Geocel, etc) will work just fine.
I am sure you can find that screw in stainless but they may not be available with the washers attached already.
Old 10-05-2012, 07:23 AM   #9
Why, the screws sold in Home Depot or Lowes in the metal roofing area will out last that roof and cost at least 1/2 as much.
Old 10-05-2012, 07:34 AM   #10
I agree....I was just answering the original question.
+1 on getting the new screws that are coated and come with the washer.
Old 10-15-2012, 02:40 PM   #11
Leaking metal carport; Thanks
I'd like to thank everyone who offered help with stopping the metal carport roof from leaking.
After a couple of days of raining there is one small leak that I need to find and eliminate.
I replaced about a third of the screws/washers on the roof. Some of them that I replaced had a burr that had been kicked up by the self-tapping screws and had cut the rubber washer in a spiral cut. I flattened the burrs down with flat punch before installing a new screw and trying not to tighten it down too much.
I sealed all of the screw heads with Vulkem 116 polyurethane sealant.
I tried to clean out the edge of the seam where the panels overlap. I then put a bead of Vulkem 116 in the gap. I tried to keep too much caulking from protruding out of the joint. Most of the gaps at the panel joints were about an eighth of an inch thick due to the large amounts of silicon sealant between the panels that I assume was applied when the roof was installed. The silicon generally was only stuck to one side of the metal and I removed what I could clean out to make room for the polyurethane sealant.
Time will tell how well I sealed the roof.
Thanks again for the help.
Old 10-16-2012, 12:24 AM   #12
I know alittle about alot
JWilliams850's Avatar
that is the style of metal roofiing joe. its designed to be put down with screws not clips and a seamer. but i agree the panels shouldnt have been two pieced and if they were forced to two piece the panels they should have been overlapped a significant length.
JWilliams850 is offline   Reply With Quote
Tags
carport roof , exposed fasteners , leaking metal
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 02:41 PM
metal roof conversion ionized Roofing/Siding 5 06-19-2012 08:57 PM
Metal roof questions Zedman53 Roofing/Siding 20 02-04-2012 11:32 AM
Help- leaking flat roof, alum?metal? xoroniox Roofing/Siding 1 04-24-2006 11:03 AM
