Mansard Shed Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-28-2006, 11:26 AM   #1
Mansard Shed Roof
Older shed with Mansard roof, previous owner built. Leaks around the top edge now. Looks like he just bent the 3 tabs for the transission. What can I do to prevent future leaks? I was thinking of going up to the first edge and adding some flashing and then continue to the top?
Thanks CK
Hay1966 is offline   Reply With Quote
Old 08-28-2006, 11:52 AM   #2
Commercial Roofing
AaronB's Avatar
If it were mine, I would do it as you say youre going to.
I have had customers say no to the flashing at this transition because of the few dollars extra involved with doing it right.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 08-28-2006, 07:37 PM   #3
General Contractor
joasis's Avatar
You can get a colored flashing, similar to a drip edge, to make the transition with, so it isn't as noticable....sad to say anyone would skimp on $20 worth of flashing, not to mention it is a pain to fold shingles over a transition. Also, the shingles will fail pre-maturely on the edge due to being bent over.
joasis is offline   Reply With Quote
Old 08-29-2006, 08:35 AM   #4
Rewards Points: 150
you can also break up the transition with a trim board running accross it.we often use Aztek,or a Permatrim material with stainless nails for no maintenence. makes it look nice
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing/Siding 21 06-18-2007 09:58 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
How to roof a small shed???? Sellncars Roofing/Siding 2 09-23-2006 12:21 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
Flat or shed roof Lonicera Building & Construction 2 12-23-2005 03:56 PM
