Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-24-2008, 05:53 PM   #1
lowest pitch for shingles
I have a roof deck with about a 1/12 pitch, is that too low of a pitch to use shingles. There is a some type of membrane on it right now but I want to stay away from the membrane. Thanks for any advise.
redrider is offline   Reply With Quote
Old 02-24-2008, 05:57 PM   #2
the shingles usually have instructions on the package, if not, get the manufacturer's literature. I don't believe that most shingles are recommended for less than 3/12 pitch (if memory is correct)
nacko is offline   Reply With Quote
Old 02-24-2008, 06:04 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I believe it is 3/12 for roof shingles.
Rubber roof for you my friend...
- Build Well -
Old 02-25-2008, 06:46 PM   #4
Super Moderator
Yes it is too low of a pitch for composition shingles to be applied, even if you were to install a continuos solid covering of Grace Ice and Water Shield under them, they would deteriorate significantly quicker, due to not being able to shed the water away from them as required.
The asphalt composition portion of the shingles are not made to be left in a saturating condition for prolonged periods of time. They would shortly begin to deteriorate and become crumbly and brittly, once again requiring a new roof application.
By the time that you add in the cost of installing the Ice and Water Shield membrane, plus the asphalt shingles, (even fiberglass shingles have asphalt composition contained within.), you would be about at the cost of having installed an appropriate flat roofing membrane in the first place, which will last much longer.
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-02-2008, 11:38 PM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
Reframe a new deck,or use IB roof systems for a lifetime warranty
"If it`s worth doing,It`s worth doing right!!"
the roofing god is offline   Reply With Quote
Building Roof over Roof, changing pitch Thomas O Roofing 7 03-05-2008 10:51 PM
Driveway Pitch handy man88 Building & Construction 6 09-11-2007 06:15 PM
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing 21 06-18-2007 09:58 AM
Changing Pitch over roof. tying into house rafters? EnlightMent Roofing 3 03-27-2007 01:16 AM
low pitch reroofing maf Roofing 2 02-04-2006 02:29 AM
