Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-02-2012, 10:38 PM   #1
Low spot and leak in flat roof?
How does one build up low spots in flat roofs that are ponding and might be leaking?
(Is there a trick for checking leaks anyway?)
We have a hidden gutter system which has a flat section on the edges that sends the water to downspouts every 20 feet or so, and a weird delayed leak at a corner near the section with the ponding problem. The main roof is (I think) 3 in 12 asphalt shingles. Very attractive, but not a good design for the rainy Pacific NW!
I thought of just getting some roofing felt and layering up strips to see if that helped; I would only put in adhesive if it worked.
Any ideas would be appreciated!
forkandwait is offline   Reply With Quote
Old 06-04-2012, 11:43 PM   #2
RFN-4A-LVN
Roofmaster417's Avatar
Could you post some pix ????
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
tinner666 (06-05-2012)
Old 06-15-2012, 12:32 AM   #3
you can buy 5 gallon buckets of whats called emulsion, its like a thick pudding. spread it out in the low spot and let it dry, might have to repeat. ive use this on many roofs and it does the job. after you have it built up then coat it with elasticmeric roof paint to tie it into the existing roof. believe youll have to buy the emulsion at a roofing supply house, homedepot might not know what your talking about.
hotrod351 is offline   Reply With Quote
Tags
leak, ponding, roof
will a flat roof always leak............. cappuccino Roofing 6 04-19-2011 05:16 PM
Small leak in low-slope roof Phillip99 Roofing 4 11-19-2010 06:30 PM
Question about vents on roof and roof leak. fenster4 Roofing 1 10-28-2010 02:49 PM
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Finding leak in flat roof Thurman Roofing 2 08-01-2009 09:47 AM
