Low Slope Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 05:45 PM   #1
low slope roofing
I live in calgary and need to do a re roof on my house, it would sure be nice to know the best thing to put on my 1/12 roof?
pugo is offline   Reply With Quote
Old 03-23-2011, 07:32 PM   #2
Pictures please
flatroofing is offline   Reply With Quote
Old 03-23-2011, 08:03 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Probably some kind of torch-down roofing membrane or at the least a roll roofing.
Andy.
AndyGump is offline   Reply With Quote
Old 03-24-2011, 06:17 PM   #4
Doing This Way Too Long
Rewards Points: 532
it really depends on the size of the project and amount you are willing to budget. You are now going to get a million suggestions depending on the respondent's preference.
OldNBroken is offline   Reply With Quote
Old 03-29-2011, 09:39 AM   #5
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I do never recommend torch down roofing for an amateur DIY'er. Please for your sake pick somethign else so you don't burn down your house. Also remember that there is no forgiveness on a flat roof. if you make on mistake it will leak.
Learn more about your flat roofing options: Low Slope Roofing
Not knowing anything about the project it's hard to make a recommendation. I personally prefer thermoplastic membranes like PVC and TPO however it takes specialized equipment and a little bit of know how. Therefore when it comes to DIYers I usually suggest self adhering modified bitumen. It's EZ to install, it is expensive, but it's a little bit harder to make a mistake. I also often recommend EPDM for the DIYer because it's easier to install then the PVC or TPO. EPDM will be a little bit cheaper than the SA Mod Bit, but takes a little more know how.
Keep in mind that the roof is a SYSTEM. This means more than just the membrane. Do you need insulation, cover board, ventilation, specialty flashings? Is a tear off necessary? The considerations for low slope roofing options are numerous.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 03-29-2011, 02:59 PM   #6
Low Slope Roofing
Rewards Points: 114
Pictures would be a great help here.
1985gt is offline   Reply With Quote
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 05:10 AM
Steep slope roofing Installation asmith_01 Roofing/Siding 3 01-09-2011 05:20 PM
Multiple Roofing issues on my home. *HELP!* 2bsure Roofing/Siding 4 12-16-2009 09:29 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 06:09 AM
Velux skylight install with 10 degree slope and corrugated tin roofing oliverbutthead Roofing/Siding 8 07-06-2008 09:23 PM
