Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 07-08-2011, 07:54 PM   #16
low slope roof want stop leaking
I have a leak in my kitchen ceiling , my son went on the roof to check for any cracks and sealed what ever he found , he felt that the water was getting in along the flang on the point ,because he saw alot of cracking there , so we bought some kind of roof sealer / concete patch and put several coats along and up under the flang, then he put another piece of aluminum sheeting up under and sealed that again, but we still have water stains in the kitchen , he can't find any where else it could be coming in , the roof is in great shape but this is a real problem because there are so many ups and downs on this roof ,that there is noo attic space in that area where the leak is , can you suggest some kind of sealer that we can spray that whole section with that will form a protective shield or completely seal the whole area , please help me , thanks .virgo822
virgo822 is offline   Reply With Quote
Old 07-09-2011, 10:00 AM   #17
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Start a new thread and post some pics. Thanks.
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-09-2011, 11:12 AM   #18
Hello. I have been doing roofing for nearly 30 years and based on my experience, when you have a roof that changes from a 5/12 pitch to nearly a flat roof, 95% of the time it is leaking where it changes pitches. Just make sure that the roll roofing is under the shingles far enough and that no tack heads are in the rain grooves. Raise up the bottom shingles and place a good bead of roofing tar and make sure your roll roofing is tarred down good. Most importantly though, just make sure the roll roofing goes from the flat roof well upon the pitched roof under the shingles. It looked like you had water standing where it changes pitches. Roll roofing comes in 1 sq. rolls. (3'w by 33.3'L). Based on 1 of your pictures you enclosed, it really looks like to me that the roll roofing isn't going upon to the pitched roof enough. There doesn't need to be a break in the roll roofing where it changes pitches. It should be layed upon the pitched roof about 18 to 20 inches. Hope this helps. I'll be glad to help you anyway I can.
Last edited by Lawayne; 07-09-2011 at 11:23 AM. Reason: Took a second look at picture.
Lawayne is offline   Reply With Quote
Old 07-09-2011, 04:07 PM   #19
hello,
thanks for your reply but I put my quote in the wrong section , I do not have a flat roof , I have all different angels on my roof with cement tiles , the roof is in great condition but i have a leak coming in somewhere around the top point cap ...?
don't know what it's called , my son has went up there and patched it with cement patch all around where he seen tiny cracks , he did it 3 times and every time it rains ,the kitchen ceiling is still getting wet , we can't go inside the attic because the whole house has different piches and in that area there is no crawl space .
I can send you pictures if that will help you , I really need help , thanks carol
Old 07-09-2011, 09:23 PM   #20
Grumpy's Avatar
start a new thread and post some pics.
-Grumpy
Old 07-10-2011, 01:08 PM   #21
I'm gonna make you real grumpy by what I say now ....I don't know how to start a new thread , I will try ...can't I just send them to you in a reply ..thanks carol
Old 07-10-2011, 01:29 PM   #22
Moderator
kwikfishron's Avatar
Carol, go to the main page for roofing. There’s a big button on the left that says “new topic”.
Post pictures if you can. How to attach a photo to a post
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 09-14-2012, 01:19 AM   #23
I have the same problem. Does anybody know a good kind of sealant. Please I am desperate. Thank you very much.
Pau-Latina is offline   Reply With Quote
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
leaking tar and gravel roof meleis Roofing 9 01-05-2008 11:27 PM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
