Low slope roof repair
Aaron,
I appreciate your DIY spirit and ingenuity.
When you think about water and making something waterproof, it probably will serve you well to think of the Grand Canyon. That was made by water alone. Water is truly the universal solvent and in low slop application, it will find even the most infinitesimal gap/crack/seam and work its way to the lower sections and foster rot.
You might be able to band aid it for a year or two but you are back at square one at that point.
If you are planning on keeping the home for a while, I would urge you to invest in a new roof altogether and either use a TPO or EPDM roof, or build up the structure to create some additional pitch and use more traditional roofing shingles at that point.
You could also use a mechanical double locked standing seam.
