Low Slope Roof ??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-02-2006, 10:08 AM   #1
Low Slope Roof ???
I have a piece of my roof that runs less steep than the rest, and i have had two of my friends tell met that it is low slope. Why is it special? Does it require some special roofing? can I ro this myself? I understand that a built up roof is supposed to be very good for this application, but What brands and types are reputable,and there is a valley where it meats the rest of the roof(steeper part) how do I take care of that properly? Thanks
fatbob79 is offline   Reply With Quote
Old 11-02-2006, 10:30 AM   #2
i forgot to mention that i intend to rip off the old and start from scratch, i do have a little experiencewith repairing and building, but i am far from a pro. any advice?
Old 11-02-2006, 12:14 PM   #3
renovations
Low slopes, especially with a valley involved are not something you want to learn to roof on IMO. Even professional roofers will leave the low-slopes to the specialists.
Bonus is offline   Reply With Quote
Old 11-02-2006, 04:02 PM   #4
Commercial Flat Roofing
I guess that makes me a specialist.
Seriously, Bonus is right, You REALLY don't want your first low slope experience to be this one.
The professional roofers refered to are usually Residential Shinglers. The company I work for does both. Our residential guy's call us when they have low slope/flat roofs to estimate and complete the work.
Find a commercial roofer that does both residential and commercial.
Talos4 is offline   Reply With Quote
Old 11-02-2006, 09:58 PM   #5
thanks for that.
What kind of materials should I get them to use? rubber or Built up?
Old 11-03-2006, 09:45 AM   #6
Contractors have their favorite membranes to install.
This is not based on pricing or "special" arrangements with suppliers. This is based on experience, efficiency, and a little pricing.
Our company prefers Built up roofs. However, we also do Modified Bitumen, EPDM (rubber) Metal and a little thermoplastic.
I would only recommend a membrane/system after looking at your job specifically.
Each system has it's own pro's/con's depending on the situation.
Let the roofing contractor's look at the job, provide you with a proposal and go from there.
In your situation get more than one proposal, I guarantee you will get several different idea's and approaches.
Once you get them, Let us know, We'll help you navigate them.
Old 11-06-2006, 10:44 PM   #7
Thanks for the advice Talos4 i will start with the estimates and proposals and then check back for your advice again then.
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
rafter thrust/cathedral ceilings godin Carpentry 7 07-09-2006 06:44 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
