Low Slope Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2013, 09:35 AM   #16
deverson's Avatar
Rewards Points: 77
I couldn't see anything but a flat piece of flashing. Too small a picture and too old eyes! Makes sense to keep water from the sheathing or tyvek but not sure if the flashing has to get the water directed to the weep holes on the siding.
deverson is offline   Reply With Quote
Old 06-23-2013, 09:43 AM   #17
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
What picture are you looking at? Didn't you take it?
tinner666 is offline   Reply With Quote
Old 06-23-2013, 09:45 AM   #18
Pro Slate Roofer
tinner666's Avatar
Pop the siding off on both sides of the windows and the first piece below them to see if the flashing is on correctly.
Old 06-23-2013, 09:56 AM   #19
deverson's Avatar
Rewards Points: 77
Sorry I was looking at the "flashing detail" link you sent. There is 4" wide tape covering the nailing flange. Tyvek on top of the tape, j channel on top of that. And siding into the j channel no flashing was installed.
Old 06-23-2013, 10:00 AM   #20
Pro Slate Roofer
tinner666's Avatar
My pix should fill 1/2 your screen. Did you click of them? They are thumbnails and each one opens a larger pic in another window so you can views lots of them at once and switch back and forth.
Your description of what you have sounds all wrong.
Old 06-23-2013, 10:09 AM   #21
deverson's Avatar
Rewards Points: 77
Now I see what your talking about. That does seem like the correct way to do it, not my way! Sounds like a weekend drive to Milwaukee! Do you install flashing above the window also, with a lip on far enough so it extends beyond front edge of the window.
Old 06-23-2013, 10:13 AM   #22
Pro Slate Roofer
tinner666's Avatar
Yes I do! Tops are problematic depending on the siding joints and I sometimes have to get creative. The short version is that I end up with a piece that complately covers the J channel on top and goes under the siding above it.
Take some time and browse all those 'Window' pages. They should be able to assist you.
The Following User Says Thank You to tinner666 For This Useful Post:
deverson (06-23-2013)
Almost made a huge mistake shingling a low slope roof! What materials should I use? Kevin993 Roofing/Siding 16 05-29-2013 08:45 PM
Flat rubber roof. Can I add a small curb to two sides and slope run-off to the 3rd jkeuning Roofing/Siding 4 10-31-2011 11:04 AM
Flat Roof: Joist Layout, Slope, & Membrane Help Needed! dutchswan0311 Roofing/Siding 10 10-28-2011 12:44 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 05:12 PM
Roof shingles/ridge vent/low slope roof Diamonds07407 Roofing/Siding 5 04-21-2011 07:05 AM
