Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-09-2011, 03:51 PM   #1
low slope leaking
I installed a roof 8 months ago main is (old) 4/12 to a pitch change (new) 2/12 car port, i put down new sheathing then ice and water first then applied shingles.....I used a piece of flat stock (alluminum) for the transittion and I did not put anydrip edge
the roof is not leaking everywhere it is only leaking down the edge from the transittion and spreading at the eave
what did I do wrong?
how can I fix it?
thanks
bbshanny08 is offline   Reply With Quote
Old 03-10-2011, 12:28 AM   #2
Doing This Way Too Long
low slope leaking
Did you start your shingles from the bottom or the top of the roof?
Sorry, been a stressful week and couldn't resist.
Where exactly is it leaking? At the transition or at the eave? How long a run is the low slope from the trans to the eave?
OldNBroken is online now   Reply With Quote
Old 03-10-2011, 02:31 AM   #3
low slope leaking
I started in the middle guy lol
seriously tho the leak starts at the transition.I forgot to mention the flat stock I used had no safety edge. The distance is 12 ft. from eve to transition.
Old 03-10-2011, 11:20 PM   #4
low slope leaking
Well, I've seen a million of them like that. I would say that you made some kind of a mistake at the transition. The most common reason I have seen for this problem is when the lower slope roof is the only piece that is being done and the tie in is done wrong. Very common is, too much head lap on the last row of shingles before the change in pitch. That is easy to see if you just look careful at a horizontal shingle joint, how much headlap headlap the shingle below has,I have sometimes seen wood where there should be an inch and a half of headlap. I have even seen cases where the end laps of the 2 transition rows lined up and shingles will not work like that. I never used any metal flashing in a case like you have there but that could be the source of the problem also. If you were tying the flat stock into the existing upper slope you might not have got it far enough up under the existing shingles, that is just another lack of headlap problem. You need to take the nails out of TWO rows of shingles when you install a flat stock flashing to insure the flashing is up underneath far enough. Get up there with a window bar and a roofing hatchet and you will find the source of the leak right away. When I had roof jobs like that to do my men would always go up the steeper slope 5 rows of shingles. Used a few more shingles but never any leaks. You said you used ice and water shield. Did you cover the entire low slope with it? If you didn't and in a worst case senario water is backing up under all the shingles that are not underlaid with ice and water. This doesn't usually happen on that pitch but I have seen it happen many times depending on the volume of water running down the roof which is dependent on the size of the connecting area and the volume of water running down it.
lucknow is offline   Reply With Quote
The Following User Says Thank You to lucknow For This Useful Post:
bbshanny08 (03-11-2011)
Old 03-11-2011, 01:25 AM   #5
low slope leaking
I did ice & water the entire area in question
I did not do the 2 full shingle method you suggested but I WILL and in the furture I will go the safe route with 5 courses above the transition
ill double check the headlap also but this is not my first roof I have done hundreds and unfortunatly this is my first leak in 6 years of business
thanks again
Old 03-11-2011, 10:53 AM   #6
Low Slope Roofing
low slope leaking
Post some pics?
1985gt is offline   Reply With Quote
Old 03-11-2011, 02:19 PM   #7
Shut in w/o Home
seeyou's Avatar
low slope leaking
how can I fix it?
thanks
Remove the metal and shingle through the transition if you already have I&WS laid through the transition. The metal is just crating a speed bump and you've may have some exposed nail heads where you nailed it down.
seeyou is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing 22 09-14-2012 01:19 AM
Closet Light issue, Need Help mount on slope bfan781 Electrical 13 04-12-2010 09:31 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing 1 02-13-2010 05:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
